Author Topic: boyer mk 3  (Read 947 times)
Offline BPellerine
boyer mk 3
« on: June 20, 2013, 05:54:43 PM »
is anyone running a boyer mk 3 I know they don't make this version anymore I have run these on twins but never on a four.bill
1978 CB 750K ard and webers
another anfob
Re: boyer mk 3
« Reply #1 on: June 20, 2013, 06:03:10 PM »
Bill, try asking Dave500 mate, he loves the boyers and has them on his bikes, he knows his stuff as well.... ;)
Re: boyer mk 3
« Reply #2 on: June 21, 2013, 12:31:46 AM »
ive only used the micro digital bill,i have a spare one of those but use the micropower aswell,the set up is the same for the micro digital and the mark 3,the micropower set up has the rotor set a little of,youll need a timing light to set it correctly,,if your engine runs dont try and time it at the "F" mark,,just increase the rpm and watch as the timing mark advances untill it stops advancing,hold those rpms and adjust the plate to get those full advance marks toward the right hand one,dont overtighten the three screws that lock the plate youll crush it,once its set see where the idle ends up,dont worry where it ends up itll be ok,if you ride the bike properly itll be at full advance all the time anyway.
« Last Edit: June 21, 2013, 12:37:59 AM by dave500 »
Offline BPellerine
Re: boyer mk 3
« Reply #3 on: June 21, 2013, 06:50:25 PM »
thanks d500 they used to have weak plates and the racers would not trust the solder on them so they would have them beefed up in this area but I am talking about Norton twins and about 15 years ago.are the modules the same as later ones my worry would be parts.bill
another anfob
Re: boyer mk 3
« Reply #4 on: June 22, 2013, 12:22:51 AM »
the plate and rotors are all the same and will trigger any unit,its a reluctor type,if your old mark 3 module craps out you can use any of the later modules with it,gremlin race tech seem to have the best prices i think?
http://www.gremlinracetech.com/product/BBMP
you can download the install instructions here,cheers mate.
http://www.boyerbransden.com/instructions.html
« Last Edit: June 22, 2013, 12:29:34 AM by dave500 »
Offline BPellerine
Re: boyer mk 3
« Reply #5 on: June 22, 2013, 05:14:26 PM »
thanks dave mine is still in the original box with instructions.would just hate to install and not be able to get parts.thanks again.bill
another anfob
Re: boyer mk 3
« Reply #6 on: June 23, 2013, 02:39:32 AM »
the boyer units are solid,and i think little used in the states?they seem to be thought of as like lucas or something coming from england?while guys seem happy to just swap out dynas over and again?no posts here about failing boyers?the one you have works fine with the stock coils,as does the the micro digital,dont use dyna 3 ohm coils,,stick with 5 ohms,i like the boyer bransden units,,they are so good pazon have a page on their website #$%* canning them!how childish?ex boyer personel..
http://www.pazon.com/pages.php?pageid=10&mode=preview
ha!looks like you have to enter your details now to view that for free as its valued at 25 sheep dollars?
« Last Edit: June 23, 2013, 02:48:17 AM by dave500 »
Offline BPellerine
Re: boyer mk 3
« Reply #7 on: June 23, 2013, 04:39:54 PM »
I never did have any problems with them in the past.Here in Canada we had a choice of the boyer or lucas Rita for our brit bikes the Ritas were expensive!bill
another anfob
