Author Topic: Front wheel won't spin freely.  (Read 3095 times)
Offline mcswny
« on: June 21, 2013, 05:32:12 PM »
So fixed my leaky fork seals and put everything back together. Just lastly put my brake caliper and tightened it down and bleeded my brakes for good measure. Now my front wheel won't spin freely at all. I tried a caliper adjustment but that didn't do anything, I assume because that's only for the static pad. It just seems like my piston is not relieving any pressure to compress back in the housing so the contact isn't constant.
Thoughts?
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline Vinhead1957
Re: Front wheel won't spin freely.
« Reply #1 on: June 21, 2013, 06:01:48 PM »
Stuck brake pad!  You should be able to compress the pads even with fluid.
Offline mcswny
« Reply #2 on: June 21, 2013, 06:13:07 PM »
Any thoughts how to keep it un stuck? It wasn't getting stuck before?
1972 CB750 K2
1975 XL250
198 XR80
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: June 21, 2013, 06:14:27 PM »
Good chance the speedo drive unit is not installed correctly-the tabs aren't seated...Larry
Offline mcswny
« Reply #4 on: June 21, 2013, 06:18:35 PM »
I don't think it's the speedo, once I take the caliper off it spins perfectly
1972 CB750 K2
1975 XL250
198 XR80
Offline kghost
« Reply #5 on: June 21, 2013, 06:44:32 PM »
Master cylinder plugged up or sticky piston in the caliper
Stranger in a strange land
Offline MoMo
« Reply #6 on: June 21, 2013, 07:46:48 PM »
If the speedo isn't seated right the wheel will be off center and will spin freely if the caliper is loose but when the caliper is tightened it rubs against the disc preventing the wheel from spinning.  I've never done that  ::) ::)...Larry
Offline mcswny
« Reply #7 on: June 21, 2013, 07:56:09 PM »
Interesting, other than horizontal is there anything special about the way the speedo should be placed? It isn't 100% horizontal, it's pointing up just so slightly.
Now I unfortunately broke my caliper adjustment bolt. Need to get a new bolt. Is this something I can just get at a hardware store that has the correct thread/lenght. God I hope so,
I'll try the speedo in the morning, I gave up and got frustrated tonight.
1972 CB750 K2
1975 XL250
198 XR80
Offline bjbuchanan
« Reply #8 on: June 21, 2013, 08:08:34 PM »
Yeah just bring the bolt along with you to a store. Probably an m6x1.0 knowing old metrics but I could be wrong with that little sucker. It will be somewhat standard so any decent hardware, nut/bolt section will have it
Offline MoMo
« Reply #9 on: June 22, 2013, 12:01:52 AM »
That is the size and a good hardware store should have one in stock...Larry
Offline Viktor.J
  • Breaking in the forum
« Reply #10 on: June 22, 2013, 12:20:07 AM »
Whats the deal with the speedo drive ? ...confused...
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
Offline mcswny
« Reply #11 on: June 22, 2013, 02:55:37 PM »
Figured it out, it was a combination of the caliper getting off center and the pad and piston sticking. Pulled the piston and thoroughly cleaned it and the pad, and then readjusted the caliper and all is good!
Speedo doesn't work  :'( Whatever. I can fix that, at least I can get out and enjoy the sun.
Thanks everyone.
1972 CB750 K2
1975 XL250
198 XR80
Offline kghost
« Reply #12 on: June 22, 2013, 03:17:07 PM »
Inner cable still intact? Spinning at the speedo end with the wheel?
