Author Topic: Front wheel wobble  (Read 1410 times)
Offline lucius cornfield
Front wheel wobble
« on: June 21, 2013, 06:07:30 PM »
Hey guys,
This'll be my first post. I recently acquired a 1974 cb550. I've got it running great. I have however noticed a slight wobble in the front end and realized the front wheel isn't true. My experience with spoked wheels is very limited but I was wondering if its possible to true up the front wheel without removing the tire.
Thanks
1971 CB350
1974 CB550
1986 VF700
bollingball
Re: Front wheel wobble
« Reply #1 on: June 21, 2013, 06:12:02 PM »
I think you can but first look and see if it is the wheel or tire. Could it be the tire is not seated good all the way around? You could rig up a crude indicator with a coat hanger.
Ken
Offline Lostboy Steve
« Reply #2 on: June 21, 2013, 06:46:36 PM »
I have the same issue, however mine is caused by a slight divit in the rim itself. I have been up to 90mph without issue. I will be replacing eventually but for now it'll do.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline davesee
« Reply #3 on: June 22, 2013, 12:40:57 PM »
there's a good write up in the FAQ for truing with the tire on. it is far easier to do it with them off, however. you could have your local shop dismount the tire for you, and you can take the rim home and work on until you've gone totally nuts ;D.
i've done both and the latter was more successful. for the tire on method i used a microphone stand with a piece of chalk taped to it.
1980 honda cb650 with many weekends worth of modifications.
« Reply #4 on: June 22, 2013, 02:43:49 PM »
There are a number of things that could cause a wobble in the front end, I would not be riding it until i had checked the wheel bearings, steering head bearings, all the appropriate spacers, brakes  and the wheel for out of round... All of which could quite easily spit you off down the road.....
