Author Topic: Getting a stuck spin on oil filter housing off?  (Read 3526 times)
Offline mcswny
« on: June 22, 2013, 03:03:42 PM »
I have one of the chrome spin on oil filters and I can get it off for the life of me? It's on there so good.
Any tips?
This one is pretty beat up so I ordered a new one, and wouldn't even mind going back to the OEM filter housing. So damaging this one more isn't a worry. Just want it off.
Thanks.
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Re: Getting a stuck spin on oil filter housing off?
« Reply #1 on: June 22, 2013, 03:10:29 PM »
Old trick is to drive big screwdriver through it and use it as a lever.  The filter housing is thin metal, screwdriver will pierce it easily, but there will be oil mess to clean.  Better be prepared for it.
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #2 on: June 22, 2013, 03:16:45 PM »
I use a strap wrench (Snap On) to take tough ones off.  If it fails I go to the chain wrench.  I have never had one that it would not take off but sometimes it totally destroys them.   I have used heat before to loosen (semi melt) the rubber seal.  If it completely comes apart (the metal can) you may be able to tear it apart down to the threaded adapter, grab it and then turn it and whats left of the filter base out.  Its a commitment thing.....once you start the destructive process you have to keep going till it comes apart.  I have seen them require cutting off the base with a torch and bringing out the pipe wrench.  I hope yours doesn't take you that far.  I am not an advocate of driving a screwdriver through it (nothing personal 70CB750).  I am also sure there are some others on here with excellent advice.  I like the stock filter housing myself.  Good luck.
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
Offline splitt
« Reply #3 on: June 22, 2013, 04:57:59 PM »
I've had good luck with a vise-grip chain wrench. I've done the screwdriver trick also, but like it was mentioned, it's a mess.
« Reply #4 on: June 22, 2013, 05:34:10 PM »
No prob, Bootlegger56.
People who ask for help with stuck oil filter, typically have only basic tools.  I can come up with 4 or so tools that are ready in my shop to be used on a case of hard to remove oil filter - but if you have just 20sf in your backyard and one toolbox, there is a good chance that you dont have the right tool for the job, but everybody has a screwdriver.
Just saying :)
« Reply #5 on: June 23, 2013, 03:10:34 AM »
chisel it in the undo direction on its seating shoulder,,just another option to confuse you.
Offline trueblue
« Reply #6 on: June 23, 2013, 04:40:02 AM »
If you can get at it, a decent set of multigrips will undo any spin on filter, you may crush it a little, but that doesn't matter as spin ons are rubbish once they are removed anyway ;D
1979 CB650Z
Offline tomkimberly
« Reply #7 on: June 23, 2013, 04:54:30 AM »
A big pair of channel locks works great.
Offline Steve_K
« Reply #8 on: June 23, 2013, 05:19:31 AM »
I had a brain fade once removing the filter on my GMC van years ago.  Turned it tight instead of loose and it would not come off.  Screwdriver, strap wrench all failed.  My day got better when the metal cover and filter guts were removed.  There was a allen wrench socket there.  Easy then to remove.  Maybe, you may get lucky if the other methods fail.
Steve
Steve_K
  • Butch
« Reply #9 on: June 23, 2013, 06:00:36 AM »
I agree with all of the above....that's why the Snap On strap wrench was my first choice.  Its about 2.5" wide and has a 3/8 side drive for a socket wrench.  Just like everybody says...once you start wrenching on it the end result has to be removal whatever the means.
750 K5
550 K1
Offline tlbranth
« Reply #10 on: June 23, 2013, 10:19:42 AM »
I use large channelocks. Grab at the end of the filter where it won't crush easily and squeeze just enough that it doesn't slip.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline mcswny
« Reply #11 on: August 30, 2013, 08:41:43 AM »
Screws into the air filter and using a wrench as lever worked like a charm!
1972 CB750 K2
1975 XL250
198 XR80
Offline KennyRedman
  • 1976 CB550F, Indiana
« Reply #12 on: August 30, 2013, 10:04:04 AM »
Inquiring minds want to know- which approach did you use?! :)
Offline Vinhead1957
« Reply #13 on: August 30, 2013, 01:16:41 PM »
+1 pierce with big screwdriver and spin
Offline mcswny
« Reply #14 on: September 03, 2013, 04:25:45 PM »
I drilled in  2 big screws and stuck a wrench in between the two. Worked like a charm, albeit a little messy. Just got to make sure it's a thick enough screw so it doesn't bend and it's deep enough in the housing so it doesn't shred the aluminum.
Sent from my iPhone using Tapatalk - now Free
1972 CB750 K2
1975 XL250
198 XR80
Offline Bailgang
  • Scott
  • Indiana
« Reply #15 on: September 03, 2013, 04:29:07 PM »
+1
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline mcswny
« Reply #16 on: September 05, 2013, 10:10:45 AM »
Mmmm messy
1972 CB750 K2
1975 XL250
198 XR80
