The last time I changed fork oil I checked the level with a dip-stick. After adding 6.25 oz of ATF to my K7 750 forks, the level was about 14 5/8" below the top of the tubes, with the springs in place and the forks extended. It was still a bit harsh, and travel was about 2" or less when applying the front brake aggressively. I drained some oil until the reading was about 16" below the top of the fork tube, and the front end gained an inch of travel under heavy braking, and feels more compliant in general. I might drain a tiny bit more to see how it feels...
