Author Topic: Speedo drive problem  (Read 1746 times)
Offline StevieMac
« on: August 04, 2006, 12:15:57 PM »
The speedo died on my '78 750 a while back.  The speedo itself is fine and I've put on a brand new cable.
The problem is whatever is inside the hub of the wheel that engages the speedo drive itself.  The speedo drive appears to be good. I've tried 3 different ones.  Turning them by hand they work fine but when I put them on the wheel they don't really work.  With the drive connected you can spin the wheel and the speedo drive will turn the shaft but ANY resistance applied to it (like turning the cable) stops the drive from working.
So what piece is in the hub that connects into the speedo drive?  I haven't tried pulling the hub apart to take a look.  I was hoping to locate a replacement part before I got everything disassembled.
72 CB500 Cafe
78 CB750 Chopper
Gallery: http://www.sohc4.us/gallery/v/members/personal/StevieMac/
Offline OldSchool_IsCool
  • Really feeling like an
Re: Speedo drive problem
« Reply #1 on: August 04, 2006, 01:50:26 PM »
You can look at the parts fiches at
http://www.mrcycles.com/fiche_select.asp?vcc=Motorcycles&mfg=Honda#SDOWN
Search through the different fiches for your year and model.  Part numbers are listed too.  MRCycle sells them, but you might find better prices at www.servicehonda.com
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline StevieMac
« Reply #2 on: August 04, 2006, 01:59:07 PM »
Hmm, looks like possible part 5 shown in the diagram but I'm not sure as I'm not positive which piece actually engages the speedo drive.
Anyone know for sure?
72 CB500 Cafe
78 CB750 Chopper
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #3 on: August 04, 2006, 02:37:41 PM »
Make sure the wheel spacer is in place outside the rotor and there is no sideplay in the wheel. A friend bought a 550 and brought it to me because the speedo didn't work. Someone had replaced the front wheel and did not use the spacer. Only thing holding the wheel in place was the rotor. Speedo drive needs to make contact with the 2 little dents on the inside if the hub cover or it will just slip. Drive should not rotate.
Fonda Honda
Offline grumburg
« Reply #4 on: August 04, 2006, 02:40:01 PM »
Parts 6 and 7 on diagram. Spacer is part 2
Fonda Honda
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: August 04, 2006, 02:43:16 PM »
I agree. Also, make sure the wheel is snug/torqued correctly on the axle. The speedo pick-up unit shouldn't spin.
Offline SuperVel
« Reply #6 on: August 06, 2006, 03:29:26 PM »
By experience I found out that there is a stamped part inside of the front wheel on the 750F2.  There are ears that engage the mechanism on the inside of the speedo gearcase.  The part crushes quite easily if the ears are not in the slots in the gearcase.  The wheel can be removed and the stamped part can be straightened.
Good Luck
Marty
Original owner 1977 CB750F
