Author Topic: cb500f &cb550f gas tank  (Read 3001 times)
Offline forwheeldrift
  • 1972 cb 500 Four
    • pics
« on: August 04, 2006, 12:32:59 PM »
will a tank from a cb550 fit on a cb500?????
brad weingartner
Re: cb500f &cb550f gas tank
« Reply #1 on: August 04, 2006, 12:46:26 PM »
Yes. I had a 72 500/4 and a 74 550/4 at the same time and there was virtually no part that could not be swapped back and forth.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: August 04, 2006, 01:51:23 PM »
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline puppytrax
« Reply #3 on: August 04, 2006, 03:15:13 PM »
You can compare part numbers...
That won't do you any good; as the petcocks and tanks are different. But the tank mounts the same; and the fuel delivery hoses hook up the same. I have one of each tank for my CB500, and I'm leaning toward the CB550 tank/petcock, but it has more dents than my 500 tank...   ::)
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
caferacer550
« Reply #4 on: August 05, 2006, 12:30:34 AM »
Yes, they are interchangeable.
I have a 500 tank on my 550.
But there is a length difference.
The 500 tank is about 1 1/2 inches shorter.
But the mounts are the same.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #5 on: August 05, 2006, 01:34:20 PM »
The 500/4 in my avatar had a 550K34 tank. But as mentioned below, the tank is longer and wouldn't fit with the 500 seat.  I bought a 550 seat and they matched up well - other than the 550 seat hinges were in a different place from the mounts on the 500 frame.
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Offline puppytrax
« Reply #6 on: August 07, 2006, 06:59:46 AM »
Steve and Caferacer550 - are you quite sure a CB550K tank won't fit on a CB500?? Maybe it is the CB550F tank that is different length?? I know they look different (gas filler; emblem attachment); maybe they and their seats are only swappable between the same model??
I have two CB500 tanks and one CB550K tank; they measure the same. I get 18" from the inside rear of the front tank mount to the rear edge of the rear tank mount; and 19 1/4" measured along the top of the tank from the front tunnel edge to the rear edge. I only used a carpenters tape measure; and only one tank has trim, but those numbers should be pretty close.
One of my tanks is a NOS dealer shelf queen; one dent from a dropped tool. Not too bad, but HTH do you pull out a dent??
« Last Edit: August 07, 2006, 07:01:40 AM by puppytrax »
    • TVAM
« Reply #7 on: August 07, 2006, 07:04:30 AM »
DSS has a NOS 500 tank for £395. At that rate, you should get your dent pulled by a professional!
SOHC4 Member #2393
  • 1972 cb 500 Four
    • pics
« Reply #8 on: August 07, 2006, 10:01:22 AM »
thanx for all the info.. its a 72 cb500four..i found a dunstall style tank online but its for a cb 550f,if the mounts are the same then it Will fit....
Offline puppytrax
« Reply #9 on: August 07, 2006, 11:53:10 AM »
... :o :o :o...Is it platinum or just gold???...   ::)
My buddy tried welding a nut onto a dent in an old tank, pulling it with a long bolt...he says it worked OK...just grind the nut off when done...and repaint...
I expect to have to paint; but welding on a gas tank (aside from the Singed Eyebrow factor) seems like I would be burning off any of Honda's anti-rust coating that may be inside the tank...   :-\
...assuming they put any anti-rust compound on the inside of the tank...   ;D
    • TVAM
« Reply #10 on: August 07, 2006, 12:27:18 PM »
You are kidding of course.  This is 1972 we are talking about.   ;D
The best anti-rust coating I have found for my 34 year old tank is to leave it full of petrol (gas) !!
SOHC4 Member #2393
    • TVAM
« Reply #11 on: August 07, 2006, 12:31:06 PM »
It's gold, well Candy Baccus Olive actually.
Colour anyway.
http://www.davidsilverspares.co.uk/cgi-bin/dss2-cgi/ProdSel.pl?cat=1%20Genuine%20Spares|CB500%20FOUR%20K0/K1/K2|CB500K0/K1/K2%20:%20Fuel%20tank%20in%20Candy%20Baccus%20Olive/Black%20(K2)
I was quoted £400 for a professional respray so maybe that price isn't outrageous for a NOS tank.
SOHC4 Member #2393
« Reply #12 on: August 08, 2006, 04:34:37 AM »
Last NOS tank I saw on ebay hit nearly $400 and i paid $300 for one 18 months ago so that DSS price is probably OK for a resto, Candy Bachus Olive was never a UK colour it was a 1973 US colour and acording to the buletin I have is obtained by spraying Candy Gold over a metallic Blue base
  • 1972 cb 500 Four
    • pics
« Reply #13 on: August 09, 2006, 09:26:31 AM »
working on a fiberglass solo seatcowl
