Author Topic: water inside rim  (Read 1183 times)
Offline andy8190
water inside rim
« on: June 23, 2013, 06:27:37 PM »
would this make the rim not safe to use? I dont know how it got in there but there is water inside the actual rim.
Re: water inside rim
« Reply #1 on: June 23, 2013, 06:30:12 PM »
Happened when i driller my stock18.. I dont wash the bike.. Keeps the water out..
Offline andy8190
« Reply #2 on: June 23, 2013, 06:31:32 PM »
haha well this is a bike I am rebuilding so never got to ride. Also is there supposed to be two bulges on the rim in the same spot? like they ballooned a little?
« Reply #3 on: June 23, 2013, 06:44:16 PM »
Sounds like it froze with the water inside it..
Offline andy8190
« Reply #4 on: June 23, 2013, 06:48:47 PM »
Makes perfect sense. So therefore it doesn't need to be reused huh
Offline kghost
« Reply #5 on: June 23, 2013, 06:50:25 PM »
Pictures of the bulges?
Generally a bad idea to use bent rims lol
Stranger in a strange land
Offline andy8190
« Reply #6 on: June 23, 2013, 06:54:22 PM »
dont know if you can see but here they are, they bulge in just a little
Offline kghost
« Reply #7 on: June 23, 2013, 07:25:36 PM »
Can see the rim is bent inward on both sides in that spot.
I have no idea what's caused that........
Offline andy8190
« Reply #8 on: June 23, 2013, 07:38:09 PM »
hopefully my other set is okay. going to see tomorrow or some time
Offline mrrch
« Reply #9 on: June 24, 2013, 11:18:32 AM »
The welded seam sometimes give a wide or narrow spot on some rims.
my build
Offline LesterPiglet
  • 1977 CB550F2
« Reply #10 on: June 24, 2013, 11:29:43 AM »
If you can see it with the naked eye (I can) I would not use it.
Offline derelicte
  • '74 CB750
« Reply #11 on: June 24, 2013, 03:30:36 PM »
Might just be the seam that's sticking out, look for grinding marks.  Both of my rims, one from ebay one original to the bike, had what sounded like water in the rolled lips when truing.    Can't be too uncommon, just tap everywhere with a screwdriver and make sure it's all solid.
