Author Topic: '75 CB550 Emulsion Tubes - Where to get?  (Read 1978 times)
Offline sniper1
  • SNIPER1
« on: June 27, 2013, 01:09:05 PM »
Does anyone know where I can get emulsion tubes for '75 CB550? Or do I just need to remove and clean?
I called local Honda shop and I might as well have been asking for a thermal discombobulator. They had no idea what I was asking for, even after telling them and describing the item (scary....).
The rebuild kit I have installed did not have them, and not sure if they are available alone.
How are they removed and installed? The manuals I have do not cover that.
Re: '75 CB550 Emulsion Tubes - Where to get?
« Reply #1 on: June 27, 2013, 01:14:16 PM »
Remove and clean, replace only if damaged.
They get tapped out from the carb bore end where the slide needle enters.  That end is a jet, by the way, so hit it or press with something softer than brass.  If stubborn, it helps to remove the slides.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: June 28, 2013, 08:17:42 AM »
I've always been curious: Which would wear faster: the needle or the emulsion tube jet? Or do they wear at the same rate needing to be replaced at the same time?
Sniper here:
http://www.siriusconinc.com/search_result.php?make=1&model=&part=1&partno=&x=23&y=13&search=search
part no. JNH70C
If you replace the jets I would replace the needles as well.
« Last Edit: June 28, 2013, 08:20:43 AM by Duanob »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #3 on: June 28, 2013, 10:32:04 AM »
They are both made of the same material, so if they rub each other, they would both wear equally.  But, the stock needles and jet mechanical dimensions don't allow the two to touch.  The slide's needle bore size holds the needle fairly centered and straight in the bore.  Further, the needle's jet (in the emulsion tube) is 2.60mm dia.  The needle's major diameter is only 2.515mm dia.  And, of course, that tapers narrower toward the tip.
Speaking of the Cb500/ 550 carbs.  I've not measured the 750 types.
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #4 on: June 28, 2013, 02:11:41 PM »
SOHC Digger (SOHC4 handle) on here fixed me up with a set really reasonable and quick should you need to buy a set.  I am sure there are many others that have carb parts if you want to run a listing in the items wanted section.
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
Offline hereforever23
« Reply #5 on: June 28, 2013, 02:19:42 PM »
Sniper- once you get those carbs nice and clean give us an update on the hesitation thread
It sounds like there are others who could benefit from your info
Offline sniper1
  • SNIPER1
« Reply #6 on: June 28, 2013, 02:51:22 PM »
Emulsion tubes are the only thing I can think that might be causing the problem. When I rebuilt the carbs last fall everything was replaced except the emulsion tubes, mostly because I wasn't sure how to get them out, and I didn't have replacements. The manuals didn't even mention them. I did a complete disassembly (minus the emulsion tubes)  and dipped the bodies in carb cleaner for a while. I then dried them, blew every orifice out with compressed air and reassembled.
The hesitation has gotten progressively worse. It ran pretty well for the first couple of months. I was also thinking ethanol fuel might be an issue as well.
Thanks for everyones advice. If I can get some time this weekend, I'll pull the carbs and start disassembling. Not looking forward to it.....I'll post some pics of the tubes when I get to them.
Offline Bailgang
  • Scott
  • Indiana
« Reply #7 on: June 28, 2013, 03:55:49 PM »
I had trouble finding emulsion tubes for my 550 as well, I spotted a new set for a 550F but wasn't sure if they would work being mine's a K. What I ended up doing was ordering rebuild kits for all 4 carbs on ebay from a Japanese seller and his kits were the only ones I ever spotted that came with the emulsion tubes. They weren't exactly the same as the factory tubes, only diff was the new ones didn't have as many holes in the side but they worked and the bike runs well now. I didn't want to mess with drilling more holes to match the factory ones because that's why my originals were screwed up in the first place, I had messed around with them when I should've left them alone until I actually knew what I was doing. :o I'll check ebay to see if I can find a link for you.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline Bailgang
  • Scott
  • Indiana
« Reply #8 on: June 28, 2013, 04:09:03 PM »
Well I found the seller on ebay but it doesn't look like his kits come with the emulsion tube anymore. Sorry.
Scott
71 cb350 twin
77 cb750 F2
