Author Topic: CB 500 vs CB 550 case front fork  (Read 1098 times)
Offline Lars
« on: June 28, 2013, 06:21:53 AM »
Except for the part number, can anyone tell me what the difference is between the CB 500 and CB 550 case front fork? They do look the same outside, but is it different inside regarding the pipe, front fork? Thus not interchangeable?
...if you got the ability to act...
Re: CB 500 vs CB 550 case front fork
« Reply #1 on: June 28, 2013, 07:32:10 AM »
The damper internals very a lot along with some of the outer dimensions although the fender and caliper brackets will transfer, also the 550 has the bracketry for a second caliper.
Due to the differences it is better to swop complete legs, as pairs, and these will slide straight in.
Having said all that, here in UK i did many years ago just change the one slider on a 500 for a 550 one so i could fit twin discs and never had a problem that i knew about!!!
« Last Edit: June 28, 2013, 07:34:06 AM by bryanj »
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: June 28, 2013, 08:05:33 AM »
From another member I found out the top cap bolts are different. The 500 has a long damper rod that screws into the bottom of the fork cap. The 550 just has the spring rest in the bottom of the cap.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #3 on: June 28, 2013, 09:56:01 AM »
Only the very first 500 have the long rod K2 deffinately didn't neither late K1
Offline davis96
« Reply #4 on: June 28, 2013, 10:04:51 AM »
550 is longer than early 500
'74 CB350F - sold
'71 CB500K
Offline Deltarider
« Reply #5 on: June 28, 2013, 10:58:01 AM »
There's quite some variation. Check the Parts Lists and sites like http://www.motogrid.com/pages/OemParts?aribrand=HOM.
CB500K2-ED Excel black
Offline Lars
« Reply #6 on: June 28, 2013, 12:00:24 PM »
Hm, that is a few differences, think I will go for the original cases on the project I am working on. I have access to nos cb 500 cases but l work on a cb 550. Thanks for all replies, guys.
Lars
