Author Topic: Conversion to double disc for CR Build  (Read 1364 times)
Offline theulsterman
« on: June 28, 2013, 02:09:32 pm »
Hi, could anyone help me by telling me what fittings I should get for the second brake disc I need for the CR build. I have both discs and the original caliper. Are the calipers and fitment bar  interchangeable or do I need to get a different type. My donor bike was a 1976 CB750 F1, it was fitted with the standard caliper,regards Kenny
Offline MFHP
Re: Conversion to double disc for CR Build
« Reply #1 on: June 29, 2013, 01:48:25 pm »
the F1 Calipers and brackets  just need t be turned to get them mirrored to the rihgt side.
« Reply #2 on: June 30, 2013, 04:06:35 am »
Thanks, wasnt sure if you could do that, next problem is finding one, regards Kenny
« Reply #3 on: July 01, 2013, 08:34:57 pm »
F0, K7 and K8 are the same if I remember correctly. Center bleeder.
« Reply #4 on: July 02, 2013, 01:55:27 pm »
Cheers Don, your right,think I may have got one, regards Kenny
« Reply #5 on: July 02, 2013, 08:08:20 pm »
You can use a factory brake hose and tube, the hard tube will need to be rebent into a right hand shape. A double banjo bolt can handle the connection at the brake light switch.  I used the stock M/C.  It has the same pressure, just more travel. Mine stops great.
