Author Topic: cb750 wiring???  (Read 961 times)
Offline shortzt.15
cb750 wiring???
« on: June 28, 2013, 02:52:49 PM »
Hi, Im New Here And I Picked UP A 72 Cb750 For $100 No Spark, I Bought A Dohc RegulatoR/Rectifier, And I Have A Wire Diagram But On The Diagram The Ingition, Has 3 Wire, Battery Ingtion And Lights,, The Igntion On The Bike Has 4 Wires Going In And It Has Marks On It Fkr Battery Ignition And Then It Has LT And Lt2, What DoiI Wire Were, Im Trying To Use This diagram
Offline 74750k4
Re: cb750 wiring???
« Reply #1 on: June 28, 2013, 05:12:46 PM »
Well it's nice you have a new reg/rect...  but what has THAT got to do with no spark??? The diagram you posted shows a thrid item you call ignition, but  is marked as the key switch.
So, we have no spark, a new reg/rect, and, a diagram that shows the key switch. You need to attack this one item at a time. If you start changing things in more than one circuit at a time, I'm pretty sure you will become even more confused. It sounds as if the harness has been stripped out of the frame?
No spark,  is going to be central to the coils/points (or electronic pickup). Do you have voltage on the coils when you turn the key switch on? Check that as an initial starting point. It s/b on the black/white wire...  but if the harness is stripped off, then you need to trace out your hacked in wiring from the kill switch, if it still exists!
Offline Corey
Re: cb750 wiring???
« Reply #2 on: June 28, 2013, 05:19:49 PM »
When I was rewiring my k6 I found a full wiring diagram much easier to use. They look complicated, but once you get your bearings it will show where every single wire goes opposed to the simplified diagram.
If I'm correct Black hot comes from the battery to the ignition kill switch. Black/White goes from ignition kill switch to the coils. Blue and Yellow wires go to the points. Is your ignition kill switch in the "On" or "Off" position?
Offline Vinhead1957
Re: cb750 wiring???
« Reply #3 on: June 28, 2013, 05:53:55 PM »
Check the black white in the headlight bucket for 12v with key on and kill on
Offline ncstatecamp
Re: cb750 wiring???
« Reply #4 on: June 28, 2013, 09:43:19 PM »
If you plan to redo your wiring try using oldmanhonda's website to do it. I just finished, helped a whole bunch.
Offline shortzt.15
Re: cb750 wiring???
« Reply #5 on: June 28, 2013, 10:50:03 PM »
There Is No Harness Im Doing It From Scratch, I Want To Follow The Diagram I Posted, I Just Need To KnOw What The Tl And Tl2 Stands For, I Have No Way To Test Because None Of The HarnesS Is there
Offline bjbuchanan
Re: cb750 wiring???
« Reply #6 on: June 29, 2013, 09:35:08 AM »
The different positions are for regular ignition on and the parking feature which on stock harnesses is usually the brown/white wire
Screw the other schematic use that good color one and use oldmanhonda.com
Old man has an interactive on/off function to the diagram so you can isolate circuits
