Author Topic: Which CB350 is best for racing?  (Read 2503 times)
Offline nitrofish1
« on: June 28, 2013, 08:39:11 pm »
For the life of me, my google search yielded me no results, although I have previously read it somewhere that the 68-70 models of the CB350 revved to something like 10.5k rpms, and the 71-73 models only revved to 9k rpms, so if one were picking a bike for amateur road racing events, wouldn't the earlier years be better for such usage? Or after upgrades to bore and cam, and valvetrain etc. done to a later model CB350, yield it to be just as fast?
Re: Which CB350 is best for racing?
« Reply #1 on: June 29, 2013, 04:42:21 am »
nitrofish1, contact TimV840. In the VRRA he owns the P2L class on his CB350 plus has a P1 bike, he'll be able to answer. All I know is there are plenty of go-fast parts available if your pockets are deep!
« Reply #2 on: June 29, 2013, 11:06:58 am »
The later 72' & 73' CB/CL350K4 & K5's are the better motors to build up for racing,they did upgrades to a number of things internally.I have a 72' CB350K4 twin & I love it.I'd like to do a small amount of head porting to it..,just enough to still be able to run stock mufflers on it w/ a little added breathing.
Offline nitrofish1
« Reply #3 on: June 29, 2013, 12:12:56 pm »
seems to be that way for most of the Honda's I know lol
Offline nitrofish1
« Reply #4 on: June 29, 2013, 07:51:01 pm »
But didn't the CL350 motors turn less rpm's and hp than the CB350 motors? Or is it a duplicate motor and rated at less due to the rear sprocket difference between the two models?
« Reply #5 on: July 02, 2013, 02:22:18 pm »
Yes,it's a duplicate motor w/ more restrictive exhaust & lower final drive sprocket ratios,all the rest is the same internally.
Offline tbpmusic
« Reply #6 on: July 03, 2013, 06:43:16 am »
Same engine in all CB/CL 350's, 350 G, and including the SL350 K0.
Early 350's had a "fatter" cam, did get a few more rpm.
I personally don't remember that the old ones were better performers, but that's the Story.
At SL350 K1/K2, electric starter was dropped, crankshaft was shorter (side to side), non-vacuum carbs appeared.Also went to a direct kick start at SL K1 (kicker directly engaged crankshaft, so you could kick in any gear with the clutch pulled in).
It's a good platform for a racer, Honda sold a LOT of these things, and there are tons of aftermarket go-fast parts.
A relatively inexpensive way to build one and go out to get your butt kicked by vintage 2-strokes like the RD's..........no shame in that, they kicked everyone's butts back in The Day.
« Last Edit: July 03, 2013, 06:45:57 am by tbpmusic »
"If you can't fix it with a hammer, then it's an electrical problem"
Bill Lane
 '71 CB450 Mutant/ '75 CB200/ '81 CM200/ '71 C70M
Offline nitrofish1
« Reply #7 on: July 04, 2013, 01:15:29 pm »
There's a guy locally selling a CB350K motor and I'm looking at purchasing a CL350 in a few weeks for a quick winter cafe project, unless the CL350 motor is sufficient for buzzing around town? thought about putting some slide carbs on it to give the motor a little more bark and bite, some home head porting isn't completely out of the picture either....
« Reply #8 on: July 05, 2013, 02:12:26 pm »
It never hurts to have an extra motor for planning different performance scenarios...,especially if your racing.
Offline nitrofish1
« Reply #9 on: July 05, 2013, 06:58:26 pm »
I kinda wanted to purchase the CL350 for a quick over-the-winter cafe project and to get acquainted with the motor rebuild, then purchase a CB350 for racing purposes.
