Author Topic: Calculating volumetric efficiency  (Read 2910 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« on: July 02, 2013, 08:06:54 PM »
I realize that this figure is dependent on an actual CFM measurement through the head, but I'm wondering if anyone has calculated the volumetric efficiency of a CB? I'm playing with header lengths for an engine build...
Paul
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline Doctor_D
Re: Calculating volumetric efficiency
« Reply #1 on: July 02, 2013, 10:33:26 PM »
I ran the numbers once.  It took a while to do, and lo and behold it wasn't a lot different than I'd been taught.  I think I came up with 104 point something.
The rule of thumb is that for well sorted street performance two-valve motors, 105% is a safe estimate for VE.
Take care,
David
1978 CX500
1971 Norton Commando
Offline turboguzzi
« Reply #2 on: July 03, 2013, 12:58:42 AM »
paul, is it you? wow :)
i found this ages ago, quite good, try to leverage some of the parameters i put in the table
things are going to be quite sensitive to flow coefficient / minimum inlet cross section if i rmemebr right
the fit with the 500/4 dyno results was quite good, the 750/810 kawi has ended up at 90- something rather than the 102 predicted,
but is a nice baseline calc
http://forums.sohc4.net/index.php?topic=81813.msg919313#msg919313
aahhh! scheisse! he went payment....it was free before!
http://www.schmidtmotorworks.com/engine_designer.html
« Last Edit: July 03, 2013, 03:06:45 AM by turboguzzi »
Offline paulages
  • 1976 cb735
« Reply #3 on: July 03, 2013, 10:49:36 AM »
Yossef-
Yeah, in the flesh! Finally finding time to work on the RC project that's been collecting parts on the shelf for a while now, and pipes are the big hangup at the moment. I'm building 4 megas, so length is mostly going to be controlled by the space itself, but I am curious about pipe diameter. I plugged the numbers into another online calculator playing with different VEs and they all suggested header I.D. in the neighborhood of 1.02".  :o I think I'll just stick with 1.5" O.D., using the stock flanges, but I can't help but wonder if they're too large?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #4 on: July 03, 2013, 11:13:35 AM »
Yossef-
Great to see ya back!
Offline turboguzzi
« Reply #5 on: July 03, 2013, 03:09:54 PM »
for what it's worth, rene was running pipes off a CBR600 in his 500/4 racer and it wasnt slow
would measure for you but sold my F2 some weeks ago...
Offline paulages
  • 1976 cb735
« Reply #6 on: July 04, 2013, 12:54:41 AM »
CBR600 wasn't slow?  ::)  ;D
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #7 on: July 04, 2013, 01:57:47 AM »
500/4 racer was faster, much more breathed on...
+1 on seeing you back paulages...
Happy Independence Day!
Yahoos here were starting their fireworks early around 10:30-11pm last night...will probably be a loud one here, but the fireworks stores are prevalent and open year-round here...
Rednecks and their things that go bang... ;D
« Reply #8 on: July 04, 2013, 02:02:20 AM »
Paul, is that 1.5 the ID or OD on the header pipes? The stock pipes being a double wall design the ID being less of course.
Offline turboguzzi
« Reply #9 on: July 04, 2013, 11:31:36 AM »
A CBR600F2 is one fine, sweet motorcycle, just bit of a fridge. didnt bond with it, a friend needed a good bike ASAP, so it went... went back to vintage with kz750E :) a bit of a CB750 with just another cam ;)
Offline paulages
  • 1976 cb735
« Reply #10 on: July 04, 2013, 12:28:54 PM »
Good call... just looked up my previous measurements (I love combing through my own posts on here for information... ::) ) and the I.D. of the stock 650 pipes are in fact 1".
1.5" O.D. in 16 gauge is going to leave an I.D. of 1.38", still larger than stock/ suggested size.
I didn't go anywhere guys, I've just been too busy to work on bikes much at all. Finally catching up to this RC project, then I can get back to some of my own fun stuff.  ;)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
