Author Topic: Which carb sync?  (Read 7688 times)
Offline nevernoluck
  • Nope I don't have a clue
Which carb sync?
« on: July 04, 2013, 11:46:50 AM »
I know it's been asked before but which carb sync gauge set do you like best and why?
Offline Bodi
Re: Which carb sync?
« Reply #1 on: July 04, 2013, 11:53:37 AM »
As long as it works, no preference. The Morgan Carbtune packs away nice and small. A set of four vacuum gauges is cheaper but bulkier, just match the readings (connect all four to a single vacuum source and set the dials to read the same). The mercury carb sticks (if still available now that mercury is too dangerous for we civilians to handle) work great but must be kept standing up or the mercury spills out.
Other methods are discussed here now and again. I haven't read of one that sounds workable yet. I think you need four independent vacuum measurements.
Offline motosan
« Reply #2 on: July 04, 2013, 12:03:20 PM »
agree.  Don't buy anything with mercury.  Many use a simple dial gauge type, they are nothing fancy but they work.  I have Morgan Carbtune.  It's nice and compact and stows into a pouch.  Just to make less clutter in my garage, I paid extra for a pouch.  Worth it?  Totally for me!  But does it work any better than others?  Most probably not.....
77 CB550K (PD46a)
04 CBR600F4i
05 FZ600
Offline KennyRedman
  • 1976 CB550F, Indiana
« Reply #3 on: July 04, 2013, 12:04:30 PM »
I have this one bookmarked from a previous thread:
http://www.saber-cycle.com/store/product735.html
But I do like the looks of that Morgan Carbtune.
« Last Edit: July 04, 2013, 12:07:08 PM by HomebrewTJ »
« Reply #4 on: July 04, 2013, 12:27:59 PM »
I like my vintage Honda factory gauge for obvious reasons. Bought em from a ex-racer a couple years ago but see em on eBay occasionally
Offline nevernoluck
« Reply #5 on: July 04, 2013, 12:54:45 PM »
I was thinking of getting the emgo set, saw a post from before that for $89.95 you could get the gauges and the tool but now can't find the post or the site it was from, anyone else remember it?
Offline Tews19
  • I am no
« Reply #7 on: July 04, 2013, 01:00:43 PM »
I have the one stev-o provided the link to. I like it.
1970 Honda CB750 survivor.
Offline nevernoluck
« Reply #8 on: July 04, 2013, 01:11:12 PM »
Found the post it's saber cycles that has a set with the tool for $99.95 made by barracuda, think if this tool works on my 80 650 it would be the way to go
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #9 on: July 04, 2013, 01:15:06 PM »
I have this one although bought several years ago before the price exploded.  I like it because all of it fits in one blow molded case and it has all the adapters.  The valves which are necessary to dampen gauge fluctuation are also built in and seem better than the cheesy plastic ones in other kits.  I checked mine with a hand operated vacuum pump when I got it and all the gauges were reasonably close to each other.  Mostly it depends on how much you want to spend.  I could buy another motorcycle for the price they want for some of the digital units.
http://www.motocrossgiant.com/v/vspfiles/photos/151861tr-2.jpg
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
Offline tlbranth
« Reply #10 on: July 04, 2013, 01:33:57 PM »
But if it doesn't work, it'll be because there's something wrong with your bike and you're the only person who ever had a problem.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline nevernoluck
« Reply #11 on: July 04, 2013, 01:37:18 PM »
Didn't mean the gauges, I meant the adjuster tool, does it fit the locknuts on my carbs
Offline nevernoluck
« Reply #12 on: July 04, 2013, 01:41:01 PM »
I like the looks of that kit too
Offline Johnie
« Reply #13 on: July 04, 2013, 02:51:37 PM »
Have to go with my Morgan Carbtune...been using it problem free for over 10 years now. Would and could not be without it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline lucky
« Reply #14 on: July 04, 2013, 03:32:33 PM »
When you get the dial type vacuum gauges you will then realize what a pain in the @$$#$! the manometer type was, and you will NEVER go back.
Replace the rubber hoses with something better.
The hoses that come with the gauges are junk.
« Last Edit: July 04, 2013, 03:36:50 PM by lucky »
Offline nevernoluck
« Reply #15 on: July 04, 2013, 04:12:35 PM »
So if that's the case jcwhitney sells the emgo for 58, looks like that's what I'll go with
Update: would've ordered from jcwhitney until they wouldn't accept my order because I was sending it to somewhere other than my billing address
« Last Edit: July 04, 2013, 09:19:27 PM by nevernoluck »
Offline KC_Northstar
« Reply #16 on: July 04, 2013, 04:59:12 PM »
I have a Morgan Carb Tune.   Paid $120.00 including shipping.   No calibrating like the dial types and more accurate and easy to read.
KC
1971 CB750-K1
1972 CB750-K2
1971 SL350-K1
1971 SL125-K0
1979 CM400A
Offline chewbacca5000
  • I polish covers!
« Reply #17 on: July 04, 2013, 08:26:27 PM »
Here is a manometer I make today it uses tubing, 2 stroke oil, and hinges with wing nuts are used to dampen the pulsing of the carbs.  I had the same exact guage lucky suggested but number 3 broke and I can no longer zero it out.
You will need valves to keep the needle from bouncing all over.  If your getting the dial gauge make sure you have valves or a way to pinch the tubing like the hinges.
I would not pay for manometer when you can make one with all parts and 2 stroke oil for less than $30.  Nice part of making one is that it can be any size or shape.  I made one like https://www.youtube.com/watch?v=E2J_N4VVGGo but am using 2 stroke oil.  Hope it works out ok.
« Last Edit: July 04, 2013, 08:28:11 PM by chewbacca5000 »
Offline tlbranth
« Reply #18 on: July 04, 2013, 09:07:33 PM »
I like my mercury manometers but I think I'd opt for gauges over the manometers that use lightweight fluid with crossovers or reservoirs that have to be accurately filled or damped or whatever. From what I've read they're a pain in the neck to use.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Omnicef
« Reply #19 on: July 04, 2013, 10:44:40 PM »
I have the motion pro one. The secret is to follow the directions... otherwise you could lose your fluid.
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #20 on: July 05, 2013, 11:33:21 AM »
i have set of the jc whitney vac guages and like them better than the fluid types.  i do need to obtain some new valves as the cheapy plastic thingys are wearing out........used em for about 7 years now
MATT
  • I polish covers!
« Reply #21 on: July 05, 2013, 01:03:53 PM »
I would get a good quality dial vacuum gauge with valves.  Tired my homemade manometer and number 4 had so much vacuum it wanted to suck all the fluid out.  After messing around for a while I gave up and was able to get my dial gauge working good enough to get all 4 carbs fairly close.
Ideally you will be able to zero out the gauge, or have something that is so accurate it won't need any messing with.
Here is a pic of setup same as Lucky posted but I use hinges with wing nuts to control the needle bounce it works great.  Very little bounce on the needle.
If someone is a pro with the liquid setup I'd like to hear what I am dong wrong.  Don't want to toss it quite yet.
bollingball
« Reply #22 on: July 05, 2013, 01:06:10 PM »
Anyone got a link for some extra nice dampening valves maybe brass? Not the cheap plastic crap from a fish tank.
Ken
  • I polish covers!
« Reply #23 on: July 05, 2013, 01:19:43 PM »
Ken
They make metal ones too got one the way from Amazon.com  http://www.amazon.com/gp/product/B009ENEZKU/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
Offline mrrch
« Reply #24 on: July 05, 2013, 01:22:48 PM »
My new Honda vacuum guages use brass valves similiar to this
http://www.123rf.com/photo_5149263_plumbing-in-line-tubing-brass-valve.html
my build
