Author Topic: ...when it says it may cause harm to aluminum...  (Read 1787 times)
Offline Lumbee
    • My pics...
« on: August 06, 2006, 12:03:39 PM »
...it means it WILL cause harm to aluminum!!!
http://pg.photos.yahoo.com/ph/marklocklear/detail?.dir=cf51&.dnm=174cre2.jpg&.src=ph
 :o
...ok, so I forgot and let it there overnight.... ::)
"I'm not a welder, but I play one on HondaChopper.com"
Offline Pinhead
  • 1979 CB652-ST
Re: ...when it says it may cause harm to aluminum...
« Reply #1 on: August 06, 2006, 12:44:06 PM »
 :o
lol Wow. That stuff isn't purple by chance, is it? I did the same thing using Zep Inudstrial Purple cleaner...
« Last Edit: August 06, 2006, 12:45:42 PM by Pinhead »
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #2 on: August 06, 2006, 01:13:15 PM »
That superclean crap is deadly.
It took the clearcoat off a set of wheels I had like it was nothing...
Rocking-M
« Reply #3 on: August 06, 2006, 07:18:10 PM »
I once tryed some oven cleaner on a set of MT valve covers for a big block. It didn't do anything though
I sure thought I'd heard it would. Looks like that stuff you had Lumbee would have done the trick.
Offline merc2dogs
« Reply #4 on: August 06, 2006, 08:04:08 PM »
 Wow, I have cleaned a lot of aluminum parts with super clean,  and never had those results!
  Normally dilute it and soak/scrub, soak/scrub though, not an overnighter.
  Thanks for posting that, I'll remember not to leave anything soaking very long from now on.
Ken.
Offline Steve F
« Reply #5 on: August 07, 2006, 09:53:31 AM »
I've heard rumors that this stuff (and Simple Green too) was banned from use in and around aircraft by the FAA for this reason.  Anybody else heard this?
Offline cbjunkie
  • ...know what i'm sayin'?
« Reply #6 on: August 07, 2006, 10:00:45 AM »
lumbee - i recognize that! - i once cleaned my float bowls with Orange Hand Cleaner - took the gas goo off great  ;D - also ate pinholes into my float bowls  :P
steveF - Simple Green? really? they make an automotive cleaner - i've not seen any warnings about it...
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
Offline Steve F
« Reply #7 on: August 07, 2006, 10:11:07 AM »
I've used it (Simple Green) under the hood on my truck to clean up the engine compartment, and it worked great as long as you rinse the #$%* out of everything and dry it right away with the leaf blower.
Offline Lumbee
    • My pics...
« Reply #8 on: August 07, 2006, 10:54:20 AM »
...yea, I don't want to scare people away from super clean...i use it on anything (aluminum or otherwise) that I want clean...just don't soak the parts in it.  Just use it as a surface clean for grease/dirt, and like steve said just rinse the chit out of it before drying...
Offline 78 k550
« Reply #9 on: August 07, 2006, 11:30:22 AM »
I sprayed some of that on my rims to clean them and they ruined them I had to polish them all up again. Looked like it took the top caot off. I was bummed I switched to simple greeen.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline Uncle Ernie
« Reply #10 on: August 07, 2006, 02:03:38 PM »
I'm trapped- I don't know what the heck to use anymore.  I finally used S100 on my Beemer and now it looks like a statue in a park that pigeons have nested on.  The streaks are killing me.  I'm thinking clean is highly over rated.
