Author Topic: Front Wheel axle nut torque  (Read 573 times)
Offline Lavis500
  • Why don't you go ask a
  • "Don't plan vast projects with half-vast ideas"
« on: July 10, 2013, 10:05:45 PM »
Hey everybody; I'm back!  After a rather extended hiatus, Operation: Enduring Rebuild is back on!  At least until I leave again...
So I was fixing my front wheel today, as I misaligned my speedo gearbox when I replaced my bearings.  After all was said and done, I went to torque the front wheel axle nut, only to find that my 23mm socket didn't fit.  I picked up a deep well, but it isn't deep enough.  I've checked every autozone/oreilly's/advance/lowes/homedepot/tractor supply around, and nobody has a crows foot bigger than 22mm.  Short of ordering one online, I'm at a loss.  So I guess my question is:  what do you guys use?  Is there a technique or another tool I can use to torque, or do I just need to cough up the money for an expensive set of crows feet?
Feels good to be back wrenching on the old girl!
"Whatever it is, I swear I didn't do it!"
'73 CB500 - Sally
Offline Lavis500
Re: Front Wheel axle nut torque
« Reply #1 on: July 11, 2013, 05:03:54 PM »
Anybody??  I know it's kind of a weird question, but what do you guys use?  I've yet to find a 23mm socket deep enough, and all of the crows feet have been GAWDAWFUL expensive.
Is everyone just afraid to admit using germantorque on that one? ???
'73 CB500 - Sally
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: July 11, 2013, 05:18:24 PM »
I can't think what I use now....but what about a 15/16 socket or ring spanner?
Oh, I just do mine up till it's tight.  ;)
« Last Edit: July 11, 2013, 05:21:25 PM by LesterPiglet »
Offline Lavis500
« Reply #3 on: July 11, 2013, 05:42:40 PM »
I'm generally pretty hesitant to try SAE tools on metric hardware and vise versa, but I may need to give it a shot.  My math tells me it's only about 0.8mm difference, so I don't think it'll be TOO loose.  I definitely have a 15/16 crowsfoot at work, so I might have to borrow that and give it a shot.
Thanks!  Sometimes you just need that one guy to kick you out of the box.  ;D
'73 CB500 - Sally
