have ripped two damn tubes trying to get one in the back wheel, now i have to drive 45 mins to get a new one. By god I am having them install it this time..... So F'in pissed right now
Used a screwdriver didn't you?
First you put the tire on the rim, Just one side. Facing the right direction.
Then you remove the valve core from the tube and inflate the tube to get all the wrinkles out.
Then you put the tube into the tire that is on the rim.
Next put the valve stem of the tube into the hole in the rim and finish stuffing the tube into the tire.
Then inflate the tube a little to make sure it is all straight and smooth.
Let the air out.
Lube the rim on both sides with soap and water.
Then start putting the other side of the tire onto the rim using your hands and finishing with TIRE SPOONS ONLY.
Start at the valve stem.
When the tire is completely on the rim make sure the valve stem is straight and
none of the tube is sticking out. Instal the valve core now.
Start inflating the tire making sure it is lining up and the bead is even all around the rim.
