Author Topic: I have ripped two M*****F***** tubes... so mad  (Read 2799 times)
Offline andy8190
« on: July 11, 2013, 04:35:47 PM »
have ripped two damn tubes trying to get one in the back wheel, now i have to drive 45 mins to get a new one. By god I am having them install it this time..... So F'in pissed right now
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
Re: I have ripped two M*****F***** tubes... so mad
« Reply #1 on: July 11, 2013, 04:47:10 PM »
LOL..........been there, done that. Might be cheaper to have someone install the tube for you-    just sayin'.
Offline surveywaters
    • My Project Photos
« Reply #2 on: July 11, 2013, 04:53:30 PM »
A little baby powder on the tubes and some air helps alot. Don't use screwdrivers! Also, heavy duty tubes are worth the money, the thicker material stays out of the way better.  I only pinch 1 out of three now that I have gottne good ;)
1972 SL125,1974 XL125,1975 CB125,1978 CB750k,1978 KZ650,1978 XS650,1985 VT1100,1986 VF700, 2005 XV1700,2003 DL1000,1982 XR250R,1986 ATC70,1987 BW80,1987 XR250R,1999 Z50r,2002 DRZ400s
Offline andy8190
« Reply #3 on: July 11, 2013, 05:07:51 PM »
did blow them up a little.
def having them install this one. I got one in but the back one is a #$%*
Offline Kenzo1979
« Reply #4 on: July 11, 2013, 05:29:28 PM »
+1 on the baby powder
Real tire spoons (3 of them), Soapy water for tire lube, and I blow them up  more than a little.  Also helps to have another pair of hands.
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
Offline GammaFlat
« Reply #5 on: July 11, 2013, 05:35:45 PM »
I wound up putting an old tube back in place because I pinched the new one.  argh
The one thing that changed my life (related to mounting tires) is lubricant.  I bought a spray bottle of stuff made specifically for this purpose.  It felt like cheating.  It worked much better than soapy water and I understand it doesn't leave the wrong kind of residue.  I don't recall the brand but I believe I bought it at the same place I bought my tires.  Here's an example: http://www.motorcycle-superstore.com/14/71/994/44833/ITEM/Matrix-Concepts-1-7-Formula-8-Tire-Mounting-Lube.aspx?WT.ac=SLIsearch
Besides making it simple to get the tire over the rim, it also makes it simple to get the tire to align on the rim.  You know those lines close to the rim... well, you need to make sure they maintain the same distance from the rim all the way around.  When you lube, the tire more easily slides into the proper place.
Good luck.
K6
85 Goldwing
    • My Project Photos
« Reply #6 on: July 11, 2013, 05:41:41 PM »
+1 on the lube, it always makes things easier. Personally, I prefer 'Tire Slick' or 'Tyre Paste' over soapy water. The water could possibly lead to corrosion.
« Reply #7 on: July 11, 2013, 07:14:56 PM »
I pinched a tube very slightly and did not know it. The front tire went down at speed. That is something you do not forget easily. I was lucky and I don;t think I will be that lucky twice. Be careful.
Offline Kenzo1979
« Reply #8 on: July 11, 2013, 07:27:33 PM »
Also, once you get the tire on, fill a little air then bang the tire around on the ground on all sides, fill more air, bounce, fill, bounce, etc...
This helps work the tube into place when you're filling the tire.
--Kenzo
Offline bjbuchanan
« Reply #9 on: July 11, 2013, 07:37:00 PM »
Been there, pinched that. The wider rear is easier, I pinched the old front and said screw it and gave it to a shop. With the front, me learning and "saving money" would have been more expensive. Drag specialties heavy tube is 19$, and they mounted it at that for me at a local shop
More expensive tube really makes a difference, they weigh twice as much and you can really feel the difference
Offline lucky
« Reply #10 on: July 11, 2013, 10:17:23 PM »
Used a screwdriver didn't you?
First you put the tire on the rim,  Just one side. Facing the right direction.
Then you remove the valve core from the tube and inflate the tube to get all the wrinkles out.
Then you put the tube into the tire that is on the rim.
Next put the valve stem of the tube into the hole in the rim and finish stuffing the tube into the tire.
Then inflate the tube a little to make sure it is all straight and smooth.
Let the air out.
Lube the rim on both sides with soap and water.
Then start putting the other side of the tire onto the rim using your hands and finishing with TIRE SPOONS ONLY.
Start at the valve stem.
When the tire is completely on the rim make sure the valve stem is straight and
none of the tube is sticking out. Instal the valve core now.
Start inflating the tire making sure it is lining up and the bead is even all around the rim.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #11 on: July 12, 2013, 04:30:48 AM »
Let the air out.
Great description. I use Ru-Glyde for lubricating the bead. Just pour some in a plastic container and use a bristle brush to slather up the tire. I will often have to reapply more than once to maintain good slip, so don't be stingy with the stuff:
http://www.pepboys.com/product/details/8446008/
Tire spoons are a MUST have. You need at least two, three can be handy. All of the tubes I tore was back in the screwdriver in lieu of tire spoon days:
http://www.harborfreight.com/24-inch-general-purpose-tire-iron-93230.html
Rim savers help protect the lip of the rim, especially aluminum. Use the lanyards! I dropped one inside the tire (on install) and struggled to get it back out! Two are better than one (two per set, four total):
http://www.cyclegear.com/CycleGear/Accessories/Tools/Tire-%26-Wheel-Tools/brand/MOTION-PRO/Rim-Protector/p/36313_00000
And finally, some short blocks of wood, 1x4x3 and 2x4x3 can be used to prop the sidewall up while you are inserting the tube into the half installed tire (meaning one bead is slipped over the rim before inserting tube... right?).
Just like everything else, it's maddening till you get the hang of it!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Kenzo1979
« Reply #12 on: July 12, 2013, 05:04:08 AM »
I've also found that a 5 gallon bucket is a great platform to work on:  Brake rotor fits right into it and so does rear sprocket, keeping both wheels stationary while you work.
--Kenzo
« Reply #13 on: July 12, 2013, 07:58:27 AM »
Keep in mind these two things,
 The beads should be to the middle, as you work the far side..easier.
 90% of good tires will go on Without irons, If you put the beads in the center..that is Both Beads, and. Beads are lubed..you need a good soft hammer the wrong one will damage your rim.
 RuGlyde is cheap.. Still got At least 1/2 of the gallon I bought in the eighties left
« Last Edit: July 12, 2013, 08:06:41 AM by 754 »
Offline phil71
« Reply #14 on: July 12, 2013, 08:36:52 AM »
a few things I've found helpful, removed the valve core. Fill tire. Let the air back out. make a bucket of warm very soapy water and slather the tube in it.
Offline Dustoff1984
« Reply #15 on: July 12, 2013, 08:46:38 AM »
My brother pinched my rear tube right at the end of a laborious install. We patched it. Tire irons + Windex + elbow grease + technique.
Offline lucky
« Reply #16 on: July 12, 2013, 01:42:16 PM »
Yes I agree...
"while you are inserting the tube into the half installed tire (meaning one bead is slipped over the rim before inserting tube... right?."
Tire in the middle of the rim (Like 754 says), too very important.
Offline lucky
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #18 on: July 12, 2013, 02:24:35 PM »
Yeah, lube that sucker with tire lube like a 2 bit harlot on half-off night.
Offline greenjeans
  • 1972 CB750K2
« Reply #19 on: July 12, 2013, 05:02:30 PM »
Gotta know - why are you guys removing the valve core ?
Offline lone*X
« Reply #20 on: July 12, 2013, 05:41:21 PM »
Allows the tube to fully deflate while installing it in the tire.  Valve core in, air can't get out.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline Vinhead1957
« Reply #21 on: July 12, 2013, 06:09:37 PM »
Also when you have to blow up and seat difficult tubeless tires it helps to have the valve out to seat the bead.
