Author Topic: Points cam orientation - does 180° make a difference?  (Read 4305 times)
Offline sweet_baby_james
« on: July 12, 2013, 12:23:50 PM »
I've put the points back onto my 78 550k after dumping the Dyna-S ignition.  Since I bought the bike with the Dyna I had to source a points cam for the advancer.  Now, obviously the advancer rotates with the crank shaft, and hence so does the cam.  The cam has one high point on it which drives the points.  So, what would happen if the cam were installed on the advancer 180° out?  There doesn't seem to be anything that will stop this from occuring? Would this mean that the 1-4 would be making when the 2-3 points should be making (ie. the 1-4 points would make when cylinders 2 & 3 are in the position to fire)?
I hope that question makes sense!
Thanks
Offline Xnavylfr
Re: Points cam orientation - does 180° make a difference?
« Reply #1 on: July 12, 2013, 01:43:28 PM »
Your question make perfect sense! You are correct to think , if it is 180 out , then 2/3 plugs would fire when 1/4 should ! BUT I've been informed on this forum ,you can't time these engines 180 degree out of time?????
If the CAM is set with #1 TDC on timing mark and your points cam was set to open #2/3 points  and you DON'T do any wire swaps I DOUBT it will run!!
I'm not from Missouri but someone would have to show it will RUN!!!
Xnavylfr(CHUCK)
Online dave500
« Reply #2 on: July 12, 2013, 02:09:21 PM »
the igniton can be set up 180 out,the cam cant,just swap the blue and yellow over at the points or coils,they have index marks,pretty hard to spot if you dont know they are there,the hitachi rotors dont have that hole,you use the logo instead.
« Last Edit: July 12, 2013, 02:13:16 PM by dave500 »
Offline Xnavylfr
« Reply #3 on: July 13, 2013, 06:28:38 AM »
Thanks Dave, I knew those point cams had an index mark somewhere to show center of high point but my eyes are not what they used to be.  I'll start using a 10X magnifying glass.
Xnavylfr(CHUCK)
« Reply #4 on: July 15, 2013, 08:21:17 PM »
Wow, I would never have spotted that.  Thanks.
James
Offline neilc
  • old school biker,other bike is a 2003 vtx1800c
« Reply #5 on: July 16, 2013, 05:30:33 AM »
doesn't the dowl on the back of the advancer set it in the correct position?
Offline trueblue
« Reply #6 on: July 16, 2013, 05:43:49 AM »
Yes it does, but the points cam can be put on the advancer mechanism 180 out. ;)
1979 CB650Z
Offline 74750k4
« Reply #7 on: July 16, 2013, 11:37:04 AM »
When you can see the dimple for maximum cam height position to adjust the points, the Big nut, and the 10mm securing nut, have to be off. If you try to adjust the points with those off, it will be innacurate, as the cam will be able to wobble, and is pushed to the side by the points rubbing block, without the nuts on the end of the shaft...  so, you will need to mark the shaft somewhere, where you can see it, assemble, and THEN set the points...
Offline crazypj
  • I'm brill, me
« Reply #8 on: July 16, 2013, 12:39:49 PM »
When the advancer backplate isn't drilled for assemble there is usually a cutway to indicate corret position ('dimple at 3:00 o'clock position)
There is also a tiny 'dot' punched into the end of points cam, it's just about visible at 5:00 o'clock position, some are even 'lighter' than this one and real hard to see
(btw, this isn't for CB750  ;))
I'm pretty sure there is no mention of these marks in any service manual or bulletin?
« Last Edit: July 16, 2013, 12:42:48 PM by crazypj »
« Reply #9 on: July 16, 2013, 02:03:50 PM »
Might be worthy of a place in the FAQ section. I haven't seen any mention of this in any manuals.
« Reply #10 on: July 16, 2013, 05:55:14 PM »
Is that dimple the high point on the cam? I am using that as a reference for setting the gap. It looks like it is a little bit off the high point on mine.
James
Online dave500
« Reply #11 on: July 17, 2013, 01:31:45 AM »
might be worth dialing that to see?it might be a precision mark?if its a rainy weekend ill have a tinker with it.
Offline crazypj
  • I'm brill, me
« Reply #12 on: July 17, 2013, 09:21:30 PM »
James
Nope, it's for assembly only
« Reply #13 on: July 17, 2013, 10:41:03 PM »
Not a word!
I used to look for it in every manual. Then, in a blank-brained moment, I took pix of it for my Tuning Appendix G in my book, but left out the text that pointed out the orientation. Duh...!
Offline Darren Jakal
« Reply #14 on: May 12, 2018, 03:15:56 PM »
Sorry about bringing this back, but does anyone have a picture that shows these marks?
I'm on an old Mac and can't update my browser without a whole lot of potential problems with the software I'm using, so I don't have a photobucket fix.
Dam photobucket #$%*ed up a lot of great threads.
Cheers, dj
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #15 on: May 12, 2018, 06:49:17 PM »
darren here are the photos that were in the replies above which you could not see.
cb750 k6 - ugly
Online dave500
« Reply #16 on: May 12, 2018, 08:34:38 PM »
here ya go.
Offline Deltarider
« Reply #17 on: May 12, 2018, 10:45:49 PM »
For some reason, most photos don't open. Hence here mine. The 'marks' (in the pic at 5 o'clock position and white encircled by me) should face eachother after reassembly. I understand the Hitachi version has a logo there instead of a hole.
CB500K2-ED Excel black
« Reply #18 on: May 13, 2018, 08:36:43 PM »
Hey thanks for the replies.
This place is great.
cheers, dj
