Author Topic: turbocharging  (Read 5549 times)
Re: turbocharging
« Reply #25 on: August 10, 2006, 01:25:02 PM »
Tom, did you run it at bonneville unfaired, ?  if so you must have taken a battering from the wind.
What class, what speeds, have you run with streamlining ? tell us more.
Sam.
Offline Tommy Neimeyer
    • Tom's Garage
Re: turbocharging
« Reply #26 on: August 10, 2006, 05:54:04 PM »
The class we ran at Bonneville was M/BF 1300cc.  We held the record from 2001 to 2005.  It is a unfaired/unstreamlined class.  Fastest we ran there was 187mph but we ran 197 at the Texas Mile in 2004.  We have never run in a streamlined class because we would have to run against all the turbo busas which have water cooling and fuel injection.  Our record was recently broken by a turbo busa that removed all the bodywork.
My son is the rider most of the time and yes, he takes quite a beating as well as the bike slipping and sliding on the salt.
Turbo7504,
What kind of turbo do you have for your project?  Are the 1088 pistons high compression?  One of many things I learned was that hanging a big piston (read as heavy) on a 15 mm pin (read as small) and trying to spin it fast is risky.  Normal high compression pistons limit boost ability due to the heat load generated.  The tops are thin and will get hot under boost and this can cause holes to appear in tops of piston, decreasing performance.  If you stay between 3-5 psi of boost should be O.K. I do not know enough about 750 rods to comment on their durability but would expect them to be at their limit at 3-5 psi boost and 1088cc (increased weight/loading).  On a street bike the carb needs to have a smaller venturi to give better response however, it will limit top end performance.
I am really interested in your project keep us posted.
Cheers, Tom
turbo7504
Re: turbocharging
« Reply #27 on: August 11, 2006, 01:30:04 AM »
right now im going to keep it at 750 or 736, and keep the boost very low. this winter when i cant ride (being that i live in wisconsin) i plan on painting that frame. At that point i will install the 1080cc kit.  im looking for strong rods and low comp pistons right now that i can put in this winter when i have the motor out.. i still want to ride this summer with the turbo and see how things go (if they go at all).
if there is a company that any of you know of that sells rods or pistons, let me know and i will check them out. keep in mind i dont need 500hp ready rods.
thanks for the help
Offline mwohlenhaus
Re: turbocharging
« Reply #28 on: August 11, 2006, 05:12:15 AM »
cyclexchange.com sells alot of hipo stuff.
Offline dusterdude
Re: turbocharging
« Reply #29 on: August 11, 2006, 08:09:30 AM »
i don't have the money or time for something like that all though that would make my day just to take it around the block.  i just turned twenty and decided that i have always wanted to make my bike different. so i got a turbo and a 1080cc bore kit.(thanks terry for showing me that it is in damn good shape and was cheaper then grass clippings.) o yeah and one of terry's oil coolers and figured that should do for now until i get some money saved up for a new bike.
i also have a 1970 dodge challenger in the garage with a balanced 440 six pack in it that goes plenty fast for my taste. so im not trying to make a 200mph coffin out of my bike i just want to make a badass coffin out of it.
thanks for all the advice
i gotta spend some time getting caught up on all the talk on here so i dont look like that big of a newb
hell yea!!!!!,another mopar guy!!!!whoo hoo
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
    • Tom's Garage
Re: turbocharging
« Reply #30 on: August 11, 2006, 07:01:56 PM »
Earlier in this thread I think I incorrectly stated the author of the book "Motorcycle Turbocharging and Supercharging" as Hugh Machinnes when it should be Joe Halle.  While the Hugh Machinnes books have small sections on motorcycles, the Joe Haile book has a lot more info.  Additionally, the book is written about the same time as the ATP kits were being produced so the tecnology discussed matches the equipment.
Joe also published a magazine in the '90s called "Turbo Bike".
Cheers, Tom
