SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Sloppy turn switch off position
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Sloppy turn switch off position (Read 1339 times)
wowbagger
Not much of an
Expert
on:
July 14, 2013, 03:16:43 PM »
I've got a 1971 CB500 with a pretty worn turn signal switch. It still works but finding the off position is getting increasingly more difficult. I dug around on the sight but didn't find any threads discussing how to repair the switch latch/divot.
The switch arm has a bump on it that is supposed to seat into a hole on the switch body when in the off position. The problem appears to be that the last 42 years of use has worn a channel into the switch body so that the bump on the switch arm no longer drops in as securely as it once did. I'll try to get some photos of the switch innards later tonight.
I'm looking for suggestions for repairing the switch action. I've contemplated everything from trying to fill the groove with JB Weld to purchasing a new 3 position slider switch and trying to custom fit it into the switch body.
Has anyone else had this issue? Were these switches just always sloppy? Maybe I've just gotten spoiled with the definitive "click into place" action on my Silver Wing.
Logged
wowbagger
Not much of an
Expert
Re: Sloppy turn switch off position
Reply #1 on:
July 14, 2013, 08:32:48 PM »
Well, upon further disassembly (and reading this thread for the right hand control:
http://forums.sohc4.net/index.php?topic=80532.0
) I found my issue.
The tiny spring behind the ball bearing in the white plastic switch block was missing. Now to hunt for a properly sized spring.
Logged
HondaMan
Someone took this pic of me before I became a
Really Old Timer ...
...not my choice, I was nicknamed...
Reply #2 on:
July 14, 2013, 08:55:31 PM »
Boy, that sure would do it! I had some ballpoint pen springs from smaller-than-normal ballpoint cartridges that worked perfectly in these. So perfectly, I used them all up...
The standard diameter ballpoint springs are a hair too big diameter.
Logged
See
SOHC4shop.com
for info about the gadgets I make for these bikes.
Link to Hondaman Ignition:
http://forums.sohc4.net/index.php?topic=67543.0
Link to My CB750 Book:
https://www.lulu.com/search?adult_audience_rating=00&page=1&pageSize=10&q=my+cb750+book
Link to My CB500/CB550 Book:
https://www.lulu.com/search?sortBy=RELEVANCE&page=1&q=my+cb550+book&pageSize=10&adult_audience_rating=00
Link to website:
https://sohc4shop.com/
(Note: no longer at
www.SOHC4shop.com
, moved off WWW. in 2024).
Bootlegger56
Butch
Hot Shot
Nuthin' taps ya out quicker than cole corn likker!
Reply #3 on:
July 14, 2013, 09:18:00 PM »
Brownells has miniature coil spring packs for firearms with OD's of 1/16 thru 5/32....but like most things you get three lifetime supplies for ten bucks instead of just the one you need.
Logged
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
wowbagger
Not much of an
Expert
Reply #4 on:
July 15, 2013, 04:19:07 AM »
Thanks for the tip HondaMan. Looks like I will be disassembling done pens at Staples today until I find the right size. If worse come to worse then I'll buy the lifetime supply, bootlegger.
Logged
wowbagger
Not much of an
Expert
Reply #5 on:
July 15, 2013, 05:34:49 AM »
Does anyone know the overall height of this spring? I found one from a pen that is roughly the correct OD but it's way too long. So, I'll have to cut it down.
Logged
wowbagger
Not much of an
Expert
Reply #6 on:
July 16, 2013, 06:21:49 AM »
Well, after pulling apart every ball point pen I own I finally found the correct diameter spring. After a bit of mangling I now have a nice and clicky turn switch again. Now, off to the store to replenish my ball point pen stock.
Logged
flybox1
My wife thinks I'm a
Reply #7 on:
July 16, 2013, 07:41:02 AM »
nice!
What model pen?
...so we have a reference here in this thread.
Turn Switch Spring
Logged
'78 750K (F3 engine) PD42b's, Modified airbox w/K&N filter, 40/110 jets, 1 needle shim, IMS@ 1 turn out. Kerker + Cone 18" QuietCore
"This is my CB. There are many like it, but this one is mineā¦"
wowbagger
Not much of an
Expert
Reply #8 on:
July 16, 2013, 07:54:14 AM »
Unfortunately, it was a freebie that I got at a trade show. However, measuring the scrap I have leftover, the OD is 5/16.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
