Author Topic: Went out today and snap there went my clutch cable Easy fix?  (Read 532 times)
Offline JACKOCASTER75CB550K
Snapped my clutch cable coming around a corner today..Is there anything I should avoid when installing the new cable? And am I going to have to re-adjust with the nut adjuster on the bottom of the cover as for I just had the clutch adjusted at my local shop?Any info or steps on the install would be much appreciated for  Ive never changed one before.I suppose I should buy a repair manual but you guys are better than that...Also how are the motion pro cables?Hopefully good I ordered 1...
Offline nevernoluck
  • Nope I don't have a clue
Re: Went out today and snap there went my clutch cable Easy fix?
« Reply #1 on: July 14, 2013, 07:11:02 PM »
You migh be able to find a manual to download here in the FAQ section but yes it should be a relatively easy fix, as for adjusting it you might be fine, try it and find out
« Reply #2 on: July 14, 2013, 07:20:11 PM »
It is pretty simple. I used Honda cables and they are fine. Just with the routing.
Offline kghost
« Reply #3 on: July 14, 2013, 07:21:23 PM »
No you generally do not need to readjust the clutch under the cover.
Install the new cable and adjust it properly.
What you do need to do is lube the cable internally before you install it.
Pro motion for example makes a cheap inexpensive cable lubrication tool.
I lube my cables about once a year. I can't remember the last one that broke.
Here is one on Ozzie ebay. I'm sure there will be one where you are at........
http://compare.ebay.com.au/like/330865881034?ltyp=AllFixedPriceItemTypes&cbt=y&_lwgsi=y&item_id=330865881034
Stranger in a strange land
« Reply #4 on: July 14, 2013, 07:47:11 PM »
Funny thing is I just had it lubed and adjusted and there was one single fray I never would of thought it would of snapped from that but I know now...I guess that was my warning..What lube would you recommend?Lithiium?
« Reply #5 on: July 14, 2013, 08:08:06 PM »
Dd you lube inside the lever ? The bending motion if its dry up there, breaks the cable..
Offline Djfob
« Reply #6 on: July 14, 2013, 08:14:15 PM »
Lubing the cable? This is something totally new to me.
78 CB750k
« Reply #7 on: July 14, 2013, 08:23:02 PM »
The shop lubed and adjusted it so I would say yes..Must of been the original cable..
« Reply #8 on: July 14, 2013, 08:30:14 PM »
Could you please advise on what side to start the cable stop on? Handle or Lever mechanism?I would really appreciate it I want to avoid trial n error if possible..Thx much for all the help with your helpful comments..I just ordered that lube tool..I would not have know about that and would of prolly snapped the new on with a dry cable...
