Author Topic: something is not quite right  (Read 1538 times)
Offline blaster802
« on: August 07, 2006, 08:08:01 PM »
hey guys first time posting great information here I have a cb750k1 that I recently got running its been sitting for 23 yrs it was mine when I was 18 great to be back on her problem is #2&3 exhaust pipe is turning purple I have been over the carbs a couple times electronic ignition I just checked today I did notice when setting the timing the advance was not the same between 1&4 and 2&3 also timing light was irratic when I had it on 2&3 I'm kinda thinking maybe a weak coil two other symptoms that I see is slight backfire on deceleration and when shes idling I get like a popping note any info or ideas would be great stock motor 4in1 jardine exhaust k&n pod filters needle on 4th groove from top 135 main jets air screws 5/8-3/4   thanks
Re: something is not quite right
« Reply #1 on: August 08, 2006, 04:20:40 AM »
"popping is usually an air leak on the exhaust plus aftermarket pipes always discolour as they are only single skin not double as originals
Offline IndianRider
« Reply #2 on: April 23, 2007, 12:23:48 PM »
can you please share with us pictures of your jardine 4 into 1 exhaust system please ...  thanks ..
Dave L
« Reply #3 on: April 23, 2007, 03:34:55 PM »
HI
I may be wrong but is it possable thant the spindle or shaft is not mounted true this will give false timing , and i think ive read about this problem
but cant remember if it only applies to the 550/440
Dave
« Reply #4 on: April 23, 2007, 04:19:56 PM »
I would have thought if it has electronic ignition that if it's right on one set of the timing, then it should automaticaly be right on the other ???
Sam.
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: April 23, 2007, 04:29:33 PM »
Sam.
I don't know about other brands, but on the Dyna-S, one of the pick-ups can be moved independently of the backing plate.
« Reply #6 on: April 23, 2007, 06:18:18 PM »
Do you mean like on the normal points Gordon ?
Sam.
Offline KB02
« Reply #7 on: April 24, 2007, 05:09:04 AM »
Yes. Actually, both pick up give you +/- 10 degrees of movement separate from the timing plate.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Andoo
« Reply #8 on: April 24, 2007, 05:13:53 AM »
Makes sense since his problem is with 2&3 which are on the same coil.
