Author Topic: Engine cleaning???  (Read 1045 times)
Offline nevernoluck
  • Nope I don't have a clue
Engine cleaning???
« on: July 17, 2013, 10:03:35 AM »
I've searched and looked in the FAQ section but can't seem to find what I was looking for, if I recall correctly I believe reading about some guys using aircraft stripper to bring back the shine to their engines, anyone know what I'm talking about or any other suggestions for cleaning?
Re: Engine cleaning???
« Reply #1 on: July 17, 2013, 10:11:17 AM »
no 'product' will bring back shine better than elbow grease...and a compound wheel.
just use simple green or S100 and a few brushes to clean your engine.
0000 and some sort of metal polish works well on the chromed bits.
Offline tlbranth
« Reply #2 on: July 17, 2013, 10:18:31 AM »
Never- the aircraft remover is used to remove the clear coating Honda puts on their shiny bits. I've never cleaned up an engine like the ones I've seen on this site but from what I've read, Flybox said it: elbow grease and a buffing wheel.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: July 17, 2013, 10:53:45 AM »
Every surface of your engine that isn't chrome plated is painted.  The only way to make it look good again is to strip the paint and then either repaint or polish it.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #4 on: July 17, 2013, 12:16:20 PM »
When I cleaned and polished the legs to my GL1000's forks Sunday I used aircraft stripper to remove the clearcoat.
The actual polishing part involved LOTS of elbow grease, 6 increasingly fine grades of wet/dry sandpaper, semichrome polish and a buffing wheel on my drill.
Offline nevernoluck
« Reply #5 on: July 17, 2013, 12:24:08 PM »
Thanks guys got the info I was looking for
Offline davidtime
« Reply #6 on: July 17, 2013, 12:29:41 PM »
Oven cleaner works good on the clear coat as well. I used it on my wheels the other day and it worked pretty good. I only left it on about 10 minutes though.
Offline davidtime
« Reply #7 on: July 17, 2013, 12:31:04 PM »
I used fast 505 on my engine and I said good bye to my nicely polished covers. I learned a nice lesson on that one.
Offline Bankerdanny
« Reply #8 on: July 17, 2013, 01:16:34 PM »
I used medium steel wool in combination with the stripper to remove the clearcoat. Wear gloves.
Offline surveywaters
    • My Project Photos
« Reply #9 on: July 17, 2013, 01:26:14 PM »
Did this dull out the polish? How long did it take to rebuff? Do you feel it was some sort of etching process?
 I have my covers taped off and want to degrease my engine before repainting and am searching for options like the OP.
1972 SL125,1974 XL125,1975 CB125,1978 CB750k,1978 KZ650,1978 XS650,1985 VT1100,1986 VF700, 2005 XV1700,2003 DL1000,1982 XR250R,1986 ATC70,1987 BW80,1987 XR250R,1999 Z50r,2002 DRZ400s
Offline reddyvv
« Reply #10 on: July 17, 2013, 01:29:20 PM »
Aircraft stripper is superb for removing paint and clearcoat. You can literally wipe the bubbled up residue off with a cloth after 10 minutes. Some areas may need a 2nd application.
Offline davidtime
« Reply #11 on: July 17, 2013, 03:14:26 PM »
Are you planning on refinishing the covers or are they already polished or painted?
    • My Project Photos
« Reply #12 on: July 17, 2013, 05:09:18 PM »
The covers are polished and covered with painters tape. I would like to degrease the case, cylinders and head. Then, lightly coat with some engine paint.  I am mainly concerned about the cleaner/degreaser making the adhesive on the painters tape goppy and difficult to remove.
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #13 on: July 18, 2013, 10:28:33 AM »
Blue house painter's tape will let solvents right through.  Green auto body painter's tape is solvent resistant.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
    • My Project Photos
« Reply #14 on: July 18, 2013, 10:32:09 AM »
That's a good clarification, thank you. All of my polished bits are masked with automotive painter's tape.
