Author Topic: Cb350f hard to get into gear  (Read 1354 times)
Offline silentsvn
« on: July 17, 2013, 04:07:45 PM »
So I just installed my new dyna s, 5ohm coils and 8.8mm plug wires and brand new plugs. I got ready to go out for a nice ride and I can't get it into gear. I roll back and forth goose the clutch with a bit of throttle and nothing finally - clunk. She goes into gear. I scream off and click all the way up to 4th. Come to a stop light and can't down shift.
Clutch fully engages and disengages.
Any thought. Really don't want to have to open the gearbox.
1973 Honda CB350 Four
2004 BMW GS 1150 Adventure
1967 Honda CL 90
Stuff for Sale
Offline silentsvn
Re: Cb350f hard to get into gear
« Reply #1 on: July 17, 2013, 04:51:49 PM »
Doh just checked the oil level and its super high. Hopefully that's it - I'll toss in a clutch adjustment to.
1967 Honda CL 90
Stuff for Sale
Offline silentsvn
« Reply #2 on: July 18, 2013, 04:57:55 PM »
Okay checked siphoned out the extra oil. Still is hard to get into first.
Any ideas or is this just a clutch adjustment. I haven't opened up the clutch.
1967 Honda CL 90
Stuff for Sale
Offline donpark1086
« Reply #3 on: July 18, 2013, 05:24:20 PM »
This is almost always a clutch that is not releasing properly.
Start at the lever and work your way down into the basket setting everything up properly.
Offline silentsvn
« Reply #4 on: July 18, 2013, 05:38:28 PM »
Okay I figured it might be. I'll go through all the linkage and set it per the shop manual.
1967 Honda CL 90
Stuff for Sale
Offline kghost
« Reply #5 on: July 18, 2013, 06:21:16 PM »
Where did all the extra oil come from?
What kind of oil is in it?
No chance there's fuel in the oil?
Stranger in a strange land
Offline silentsvn
« Reply #6 on: July 18, 2013, 06:30:11 PM »
Had to replace oil filter so I retopped off fast and wasn't fully paying attention.  it wasn't to full. More of right below the top mark.
No fuel in oil or oil in fuel.
1967 Honda CL 90
Stuff for Sale
Offline Jasondo
« Reply #7 on: July 18, 2013, 07:31:38 PM »
Should oil be checked on the side stand or upright?
Offline JACKOCASTER75CB550K
« Reply #8 on: July 19, 2013, 06:35:59 AM »
upright position
Offline silentsvn
« Reply #9 on: July 20, 2013, 10:44:06 AM »
So I went through everything as per the shop manual and it is doing the same thing just not as frequent.
I tried to adjust the barrel nut so that it would pull more when the clutch is disengaged.
1967 Honda CL 90
Stuff for Sale
Offline silentsvn
« Reply #10 on: July 21, 2013, 12:13:56 PM »
So I think I found the issue.
The clutch cable is in need of replacement -- badly.
Some shots of the clutch and friction plates. Everything was measuring at .1026 +/- on the friction plates.
« Last Edit: July 21, 2013, 01:00:52 PM by silentsvn »
1967 Honda CL 90
Stuff for Sale
Offline Timmy
« Reply #11 on: July 21, 2013, 02:26:30 PM »
Did you need any specific Honda-tool to remove the clutch? I must have mixed up the parts or models for this, but I read somewhere that you needed that.
Probably when being drunk  :o
Offline silentsvn
« Reply #12 on: July 21, 2013, 02:36:08 PM »
Nope I think thats the CB350 - you need that castleted socket.
This just unbolts and slides off after you past all the damn screws.
1967 Honda CL 90
Stuff for Sale
