Author Topic: When your throttle cable breaks...you're gonna have a bad time. Replace Ass'y?  (Read 3495 times)
Offline wiskey
So on a short test ride to test out a new master cylinder I had just installed, this happened
Lucky I pulled the bike into a lot about 25 min walk from home, had my girlfriend drive me back with some tools. Led to me removing the throttle return spring on the carbs, shoving my hand in the carbs to manually operate the slides and get her back home.
Anyways now I'm looking to replace not only the cables but also the throttle assembly.
I have clubman bars on it currently and the stock cables are a bit on the long side.
I would like to clean up the controls a bit more so I would like to go with a smaller kill switch/starter assembly as well as a new, non-oem throttle assembly and shorter throttle cables.
Anyone have any good experiences with any universal throttle assembles that you can recommend?
Also looking for a good source for shortened throttle cables. Can i make my own?
Thanks!
Offline kghost
Not unless you can cast the ends on.
Stranger in a strange land
I made my own throttle cable, well at least the top end after the original fell off.
I used flux and solder, lasted many thousand miles so far.
Some write up:
http://www.motorcycleforum.com/showthread.php?t=102449
Offline Elan
    • Vital Motor Parts
Happened to me once, The "pull" cable snapped, so I had to put the "push cable" on the pull side of the carbs to get home. Wierd feeling turning the throttle backwards when driving home. But its a good strategy if you dont have any tools on you.
76 750k
Offline Bru-tom
Some write up:
very cool, nice idea, especially that it works. I wonder if silver solder will work too?
Offline wiskey
Any recommendations on a throttle assembly?
Offline tlbranth
I'm pretty sure MotionPro will custom make a cable for you. Bring your checkbook and a cosigner.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Tews19
  • I am no
Never will I buy motionpro again. I bought oem cables from Honda last month for the K1.. as per HondaMan....... They are the bees knees
1970 Honda CB750 survivor.
Offline surveywaters
    • My Project Photos
I put a single cable Harley throttle on a Honda Shadow. Called Motion Pro and told them what I had and the length I wanted; $60 later it was in my mailbox.
1972 SL125,1974 XL125,1975 CB125,1978 CB750k,1978 KZ650,1978 XS650,1985 VT1100,1986 VF700, 2005 XV1700,2003 DL1000,1982 XR250R,1986 ATC70,1987 BW80,1987 XR250R,1999 Z50r,2002 DRZ400s
Offline lucky
Motion Pro makes very nice throttles.
Offline 74750k4
Throttle cables broke on both my 750's...     fortunately you have the throttle thumbscrew which can be cranked up to 3500+ RPM or so, and the kill switch is your friend to get you home! :) you can make it up small hills this way. Both now have the sweet MotionPro cables on them.
Offline mikejorg
I recently put clubmans on with new Motion Pro push & pull cables. Definitely get the cable lube and tool. You just have to route the cables properly (no binds, make sure it snaps back nice, little bit of play and you should be fine). I have a 77 750k
77' CB750 - In process of being cafe'd out
Offline wiskey
Well I purchased a motion pro throttle ass'y and cables.
These are the cables http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-cables-honda-cb550-throttle-cable-452-0807.html
seems the cables its self is too short by kinda alot. The overall lenght is ok, but the lenght form the housing to the end is way too short.
Is the '69-'76 a different cable from the 77&78? I guess it would make sense as the carbs are different.
Oh well time to order some different ones.
Black 750K8
Tews what was wrong with the ones you got? Whith the bar change he can not go OEM without being to long.
Offline Tews19
  • I am no
They were really off on length.  Pay the extra amount and buy OEM.  Really smooth
