Author Topic: SHORTEN YOUR CABLES ALL BY YOURSELF. EASY...  (Read 2190 times)
Offline cbjunkie
  • ...know what i'm sayin'?
« on: August 08, 2006, 09:03:04 AM »
I finally sourced the little buggers.
After my throttle cable broke a month ago I figured that it was binding due to the routing - of course, I had routed it that way because there was so much slop since i switched to drag bars.
This little item was my saviour.
http://www.gokartsupply.com/thcable.htm
strip.clip.tighten and go...
KEEP IN MIND - I HAVE NOT ORDERED THIS PARTICULAR PART - I HAVE SOME ON ORDER AND CAN REPORT ON FITMENT SOON...
« Last Edit: August 08, 2006, 09:11:06 AM by cbjunkie »
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
Offline cmorgan47
  • smaller, lighter, quicker
    • theundergr0und
Re: SHORTEN YOUR CABLES ALL BY YOURSELF. EASY...
« Reply #1 on: August 08, 2006, 09:13:29 AM »
post results, i'm switching bars soon.
i love babies...
with a nice chianti sauce and a side of fava beans
Offline Jeff
« Reply #2 on: August 08, 2006, 10:38:52 AM »
Same here.
Jeff
Offline dusterdude
« Reply #3 on: August 08, 2006, 10:47:16 AM »
cool deal
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline mcpuffett
« Reply #4 on: August 08, 2006, 02:54:00 PM »
hey cbj, they are what we in the uk call solderless nipples  :D, i personally only use them as a get me home as they are not as good as a soldered nipple  ;), mick.
Offline cbjunkie
« Reply #5 on: August 08, 2006, 03:04:42 PM »
"solderless nipples", indeed!
"not as good" - no argument there - feel like giving us a primer on making the real thing?
1971 750K1
the free men.
Zip
« Reply #6 on: August 08, 2006, 04:18:01 PM »
I just like the word 'nipple.'   ;D
Zip
Offline Uncle Ernie
« Reply #7 on: August 08, 2006, 06:29:56 PM »
Wellll- there's the website page, but exactly which of these products did you order?
Offline cbjunkie
« Reply #8 on: August 08, 2006, 07:21:01 PM »
of the three cable nuts, the 2nd and 3rd options.
1971 750K1
the free men.
Offline mrbreeze
  • Not your average
« Reply #9 on: August 08, 2006, 09:59:22 PM »
NIPPLE......yeah,I like it!!!!!!!
MEMBER # 257
Offline mcpuffett
« Reply #10 on: August 09, 2006, 04:17:02 AM »
hi cbj, i'm not that good at soldering yet so i can't really explain it but someone like hondaman or oldbiker could probably explain it better ;), (nipple)  :D,   mick.
Offline cbjunkie
« Reply #11 on: August 09, 2006, 06:10:32 AM »
pulna, pulna, pulna, pulna, pulna, pulna...
1971 750K1
the free men.
Offline oldbiker
  • I HATE RAIN
« Reply #12 on: August 09, 2006, 06:15:55 AM »
I,m usually very careful to keep hot solder away from my nipples, but if you do want to solder your cable-
open up the hole in the nipple to a 'V' shape and feed the cable through and then splay the strands out to fill the 'V'.  Solder to fill up the space but remember that electricians solder that has the flux in as a core to the solder is not really suitable for this job.  The strands of the cable are either stainless or like piano wire and you need to use an acid based flux. Wash off well when finished to remove any residue of flux..
Offline Steve F
« Reply #13 on: August 09, 2006, 06:36:48 AM »
Or, you can silver solder them with a torch and brazing flux.  On the down side to that method, you have the possibility of the silver traveling through the strands and making the cable solid for about 1/4" or more.  Silver solder works with stainless, mild steel or brass very well.
Offline cbjunkie
« Reply #14 on: August 09, 2006, 07:34:59 AM »
that seems a little counter-intuitive to me, steve...wouldn't you want, particularly, the first 1" of the cable strands to remain flexible coming out of the throttle slide?
1971 750K1
the free men.
Offline Steve F
« Reply #15 on: August 12, 2006, 04:26:59 AM »
That's why I said "....on the down side,"  You can do it without the aforementioned problem if you're careful with the heat.
Offline cbjunkie
« Reply #16 on: August 12, 2006, 08:54:44 AM »
oops - misread ya...
i forgot the buggers at the office yesterday, just realized - i'll go get them later on and see if they're gonna fit...
1971 750K1
the free men.
