Time to continue...
Next, I got the front end on and sorted. I ended up tearing down the front forks, cleaning them, polishing them, and replacing the oil with some fresh new stuff.
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150525_214210_zpswbqef8df.jpg)
The next task was daunting. I needed to figure out what I wanted to do about that large crease/dent. This was the view after sandblasting the tank.
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150526_211510_zpshkg1xvui.jpg)
The metal seemed pretty solid, so I figured I'd try to pull the dent as much as I could so that I could avoid using as much filler. So I tack welded some washers along the crease and pulled with vice grips.
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150526_213244_zpsdm0bhdsa.jpg)
I was actually surprised at how well that worked.
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150526_215839_zpsxkvtydwq.jpg)
But the dent itself was still rather deep. So I cut coat hanger to 2" lengths and tacked those to the tank.
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150527_203925_zpsznqlalm7.jpg)
That go the dent most of the way out.
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150527_204434_zpsnkotwmhl.jpg)
I didn't realize that I had pulled too hard. I ended up making a whole row of little holes at each weld spot. I had to go back and weld these up.
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150527_210920_zpsmqy8nycr.jpg)
That didn't work out as well as I hoped, and I ended up still leaving a bunch of pin holes. And the dent was still deeper than I wanted. So out came the body solder.
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150530_211836_zps3qd7jkvu.jpg)
Sanded the solder flat and added bondo. Sanded that to shape.
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150531_142557_zpsu2j8fbb0.jpg)
I was so concerned about that big dent, that I totally missed this smaller dent on top. I should have stopped once the wet primer made it oblivious, but I didn't. I regret that now.
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150531_150841_zpsbmmyh0es.jpg)
I think I matched the curve quite well.
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150606_171509_zps9p5e4ld2.jpg)
So before I did paint, I did the toilet bowl cleaner trick to get rid of the rust that had formed inside the tank from a leaky gas cap and a plugged drain hose (mud wasp).
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150623_191610_zpstr8dei5t.jpg)
While the Works... worked... I kept building. Here, I have the one side cover painted with the GM blue.
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150628_201324_zpszqenjmpm.jpg)
The tank cleaned up nicely. I swirled some Seafoam around inside to prevent flash rusting (it still flashed VERY quickly). Next was the tank basecoat. I didn't want overspray all over the garage, so I was stuck painting outside. I'm surprised how few things got in the paint.
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150725_142353_zpssbftgcnl.jpg)
I wet sanded the blue, added another coat, wet sanded again, and then started building up clear. I think I did 2 or 3 coats before I started wet sanding again. You can see the orange peel starting here.
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150725_152226_zpshts7i266.jpg)
The orange peel cleaned up nicely. Here's the finished tank, hanging in the sun to dry. I love the flake in it.
![](http://i491.photobucket.com/albums/rr274/knochgoon24/Motorcycle%20Mega%20Album/700px_20150725_161722_zpsjvnhuboi.jpg)
