Author Topic: No vac leaks, but takes time to reach set idle speed  (Read 1007 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« on: July 22, 2013, 06:18:07 PM »
My intakes have no leaks. I took a propane torch (unlit!) to the intakes and no increase in idle was found. However, my bike still idles at around 7-800 when I first start it and will die if I don't keep the revs up. After about 3 minutes of holding at 2.5K, she is warmed up and sits nicely at 1000RPM where I set it, and doesn't get any higher than that. Idles nice and smooth then.
Thoughts on the "cold blooded"-ness?
--Evan
1975 CB750K "Rhonda"
Offline nevernoluck
  • Nope I don't have a clue
Re: No vac leaks, but takes time to reach set idle speed
« Reply #1 on: July 22, 2013, 06:25:14 PM »
Adjust your idle? What bike you have? I have to adjust my idle up a little when warming bike up then after it gets good an warm back down, probably not right but I can reach right down on my 650 while I'm riding and get it done
« Last Edit: July 22, 2013, 06:58:46 PM by nevernoluck »
« Reply #2 on: July 22, 2013, 08:05:45 PM »
Unless you have the benefit of pd carb fast idle cams, you need to turn in your idle set screw to hold idle at 1500-2000, then turn it down as you get to op temps....
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #3 on: July 22, 2013, 09:16:12 PM »
If cold I crank with full choke, cut it back to about half take off and ride for the length of my development road about 1/2 mile.  Start out on the highway and bump the choke off about mid ways through third gear and I am good to go.  I never mess with my idle adjustment screw.  Doing a carb sync, thoroughly cleaning the low speed jets including the atomization holes, adding a HM transistorized ignition, dyna coils and using ND X24ES-U spark plugs along with a K2 advance unit and proper valve, timing and points adjustment have all but eliminated the worst of the cold blooded nature.  Having said that these bikes tend to be a little cold natured but for us old folks who grew up using a manual choke on our cars its just second nature.
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
Offline bjbuchanan
« Reply #4 on: July 22, 2013, 09:41:40 PM »
Don't screw with the idle knob, leave it how it is supposed to be set at when you have a warm engine. No fast idle cam means you gotta pay a little attention to the bike when warming up
Are you using your choke? Even if it is 90 degrees out it doesn't mean your engine is warm just because you are. Try full choke and see if it stumbles and dies with no attention. This 90+ weather in NY has seen me using like 3/4 choke on startup and adjusting down faster than cold weather. It isn't cold bloodedness, it is a cold engine. From your description it seems like you are doing what I described, full on and dead or off and racing rpm. You gotta work the choke, it has a range
Offline kghost
« Reply #5 on: July 22, 2013, 11:27:06 PM »
I have a 350F, a 400, a 550 and 6 750's.
They are all cold blooded.
I generally on a warm day do not have to use choke....but every one will die if not allowed to warm up.
As you said....idle around 600-800 dead cold, increasing to 1000-1200 warm. Every one of them
Stranger in a strange land
Offline evanphi
  • Apparently I'm an
« Reply #6 on: July 23, 2013, 03:54:28 AM »
OK sounds good folks. This is my first time riding an old bike. I start full choke (starts first kick) , then back off immediately to about 1/2 or full open while keeping the throttle open a bit. This always works for me, I just didn't know if it was "normal" or not.
I would never be messing with my throttle stop screw... I can't adjust it by hand without taking off my tank!  ;D
« Last Edit: July 23, 2013, 03:57:16 AM by evanphi »
--Evan
Offline kghost
« Reply #7 on: July 23, 2013, 04:03:54 AM »
They may be referring to the one on the grip.....
There was a small knob under the right switch that could lock the throttle.
Offline trueblue
« Reply #8 on: July 23, 2013, 04:52:33 AM »
Tim, the later bikes had a knob on the right side of the carb rack between carbs 3 & 4 to adjust idle speed ;)
1979 CB650Z
Offline kghost
« Reply #9 on: July 23, 2013, 06:49:52 AM »
Yeah.  Well aware of that. Most of the 750's without the 4 individual cables lol
I'm prolly one of the few that still have the throttle set screw on both my K2s lol
Offline evanphi
  • Apparently I'm an
« Reply #10 on: July 23, 2013, 06:55:00 AM »
My controls have a hole for this "cruise control" knob, but no screw in it. I don't need it. :P
« Last Edit: July 23, 2013, 07:03:37 AM by evanphi »
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #11 on: July 23, 2013, 06:55:32 AM »
Mine is on the left (1975), and impossible to get to without removing the tank. Should it be on the right?
« Last Edit: July 23, 2013, 07:03:49 AM by evanphi »
--Evan
