Now, about that non-machinist fix idea . . . . If the objective is to keep the rocker shaft pressed down in the bottom of the bore that's not worn, why not simply drill and tap holes in the cam cover above the shaft bores? Install a set screws and call it a day. If need be, grind a bit of a flat on the rocker shaft ends. Seems this would only be necessary for Nos. 1 and 4, intake and exhaust.
Wow, you're idea is just like mine! Imagine that!
![Grin ;D](http://forums.sohc4.net/Smileys/default/grin.gif)
The screws/set screws would need to be placed over each position that had bores worn egg shape. There is some concern about the screws staying tight, both for unscrewing and for oil leakage. I expect locktite could be employed to help with that, (or jam nuts).
The other concern is if the bores are also worn fore and aft as well as upward, the shaft may wander fore and aft if the screws don't stay really tight. When I was last thinking about this, two used late model covers came up on ebay for $40 ea., and I won them both. So, my interest in the set screw as well as boring and sleeving the worn covers waned significantly.
The covers I have are actually worn at each position, it's just that some were worse than others and one was so bad the rocker was hitting the inspection cover. Certainly, if there are bores that are unworn, a set screw would keep them from becoming worn in the future.
Also, recall that if one support end of the shaft has a bore worn more than the other end, then the tappet follower contact face won't remain flat with respect the the cam lobe flats. This will wear off the very thin hard coat on the tappet on one edge, then galling follows. The rocker shaft is supposed to be parallel with the cam lobe flat to evenly transfer spring loads across the entire lobe flat.
Minimize work if you want, but be sure you haven't just postponed a problem developing later on.
