Got some work done today...
Its amazing how detailing will clean up a bike so much. Its time consuming, but worth it. I spent about an hour and a half with some Simple green and a tooth brush. I got every nut, bolt, corner, crevice. I did the wheel hubs, wheels, swing arm, and frame. I then touched up some spots on the frame. I also got the freshly painted header/pipe back on, bars and controls tightened down, and hand grips installed.
This is a crappy pic, but I had to reroute the front brake line, and turn it up on the banjo fitting, to make it work well in its new position.
Here are the bars all ready to go, and everything installed and tightened up. The riding position feels good.
Last thing I did today was remove the caliper, sand, prep, and paint. Im letting it hang overnight...it turned out real nice for a rattle can.
Ill keep ya posted as I continue...
