Author Topic: 2/3 plugs not firing...HELP  (Read 959 times)
Offline seattle550k
« on: July 24, 2013, 05:45:38 PM »
Hello, new member here.
So, here is the story.  I bought a '77 550k from a guy while he was "half way" through a café racer rebuild.  Turns out there was a lot more work to be done than advertised so I started going to work.  I changed the rear shocks, put in a new regulator/rectifier, changed out the exhaust to a mac 4-1, put new sprockets and chain, adjusted the timing plate and points and various aesthetic changes.  Everything ran fine and I was on my way to Backfire Moto last week when the bike sputtered out along the way.
I checked the fuel and all is running and flowing fine.  Next to electrical, running through the checks and this is what I found.
All the plugs are getting a good spark when checked on wires 1 and 4.  2 and 3 are not getting a spark to any of the plugs.
I'm not sure where to turn from here.  Any help is greatly appreciated and welcomed. Safe trails and happy riding.
Offline surveywaters
    • My Project Photos
Re: 2/3 plugs not firing...HELP
« Reply #1 on: July 24, 2013, 05:55:32 PM »
You could start by unplugging all the spark plugs, swapping the leads at the coils which come from the points, then turn it over and see if 2/3 spark. This will tell you if it's the coil. If it's not the coil, the points are fouled.
1972 SL125,1974 XL125,1975 CB125,1978 CB750k,1978 KZ650,1978 XS650,1985 VT1100,1986 VF700, 2005 XV1700,2003 DL1000,1982 XR250R,1986 ATC70,1987 BW80,1987 XR250R,1999 Z50r,2002 DRZ400s
Offline rb550four
« Reply #2 on: July 24, 2013, 06:20:03 PM »
Be sure and check that all the wires to the coil are still plugged together tightly, Blues ,yellows  black and whites at coil, yellow and blues  near the battery where the harness connects with the brake light. sometimes wires feel all the way plugged in when they aren't, could be as simple as a loose connection.
« Reply #3 on: July 25, 2013, 09:46:10 AM »
if all connections are good....coil test directions are here
http://forums.sohc4.net/index.php?topic=5752.0
Offline seattle550k
« Reply #4 on: July 25, 2013, 12:40:20 PM »
Thank you for the knowledge and insight. I'll start tinkering and let you know what the outcome is.
Offline Vinhead1957
« Reply #5 on: July 25, 2013, 04:49:48 PM »
 Check the yellow wire under your points cover and make sure it is not grounded or loose at the points connection
Offline mono
  • Definitely no
« Reply #6 on: July 25, 2013, 06:19:04 PM »
I blew a NEW condenser the other day and it took me 2 weeks to figure it out.  swap it out and see what happens.  It was the last thing I checked lol.
Sent from my SPH-L710 using Tapatalk 4 Beta
Offline mono
  • Definitely no
« Reply #7 on: July 25, 2013, 06:19:55 PM »
I guess you know you're getting old when "the other day" was like a month ago... Lol
Offline Bankerdanny
  • Endeavor to persevere
« Reply #8 on: July 26, 2013, 08:12:16 AM »
When I had problems with my 1-4 firing intermittently it was a loose wire where the condenser attached to the points.
You could try swapping the condensers and see if the problem transfers to the 1-4's.
