This may be a silly question, but do you guys think this bearing retainer is unsafe to reuse? In my attempts to get this thing out I put a hairline crack on the underside of it. I'm not really thrilled with the idea of waiting through 1 more week of great weather to wait for this part, but if reusing this would be really unsafe then I'm just gonna have to wait it out.
Also, for the benefit of those readers that may be having trouble with their retainers, I've tried using an adjustable pin wrench & homemade bar wrench that has been documented in these forums many times. The easiest, and probably the cheapest, way that I've found was to stick two similar size drill bits face down into my vice so only a little bit of it is poking out, and then putting the wheel over the vice and using the wheel to leverage the retainer out. I just wish I figured that out before I started smacking it with a punch
