Author Topic: Replacement Regulator/Rectifier CHEAP  (Read 199889 times)
0 Members and 12 Guests are viewing this topic.
Offline Pinhead
  • 1979 CB652-ST
« on: August 08, 2006, 09:58:13 PM »
EDIT: For the most up-to-date information, go HERE
When I first got my bike the rotor was shorted and the regulator was shot. I replaced my rotor a while back, but have been driving without a functioning regulator. Just the other day I boiled my battery and fried my rectifier and rotor. Me being the tightwad that I am, I thought there must be an alternative to the $100 aftermarket R/R or the extremely expensive RR from the dealer. I was right. I went to Advance Auto Parts and got a regulator for a mid-70s Ford pickup for $13. Mine came from a '76 F150.
It has 5 wire connections:
A+ -- Battery +
F --   Field 1
S --   Not Used
I --   Ignition
Case - Ground
Let's re-examine the connections on the various regulators. Forget the letters.
One forum member's regulator is labeled "I A S F"
My regulator is labeled "A F S I"
The letters are meaningless if this is truly how they are labeled.
Just go from left to right; they are made to plug into the original Ford wiring harness which won't change even though the letters apparently do.
From left to right with the terminals facing you:
1 - Battery (+)
2 - Field
3 - N/A
4 - Ignition
Case - Ground / Battery (-)
It's really easy to wire up. The F terminal goes to one of the two field wires (brush wires to the rotor). The other field wire goes to ground. "I" goes to your switched power and A goes straight to battery voltage. You want to ground the case somehow.
There is one problem with using this regulator, however. It has no rectifier built in. I built my own rectifier using two of these:
http://guerte.en.alibaba.com/product/50065741/50345579/6A_75A_Square_Bridge_Rectifiers/Square_Bridge_Rectifier.html
Alternately, you could simply use one of these:
http://guerte.en.alibaba.com/product/50065741/50297999/6A_75A_Square_Bridge_Rectifiers/Three_Phase_Bridge_Rectifier.html
Wiring the rectifier is a lot simpler than it looks. The three wires that come out of the alternator are three-phase AC power. The rectifier will convert this power to DC.
Just to make it simple, I'll use the three-phase rectifier from above as an example. Three of the lugs will be labeled with a "~" which denotes AC power. The output of your alternator goes directly to these three lugs. The "-" lug goes to the "-" terminal of your battery and the "+" goes to the positive terminal. Since the regulator varies the output directly from the alternator, this is all you need to do with the rectifier.
I've installed this system in my '79 CB650 and it works great. The charge voltage is right at 13.3v, and it'll charge from 1500rpm and up. You'll never have to worry about burning your headlight bulbs or overcharging your battery because the electronic regulator keeps the voltage perfectly constant. Also, since it charges at 13.3v instead of 14.4v, you don't have to worry about boiling your battery in the summer time. Plus, the two rectifiers that I used are $0.44 apiece and the regulator was only $13. That puts my R/R budget to $13.88. Much better than the $100 I would've spent on the 'net or the $250 from Honda!!
Quote from: scottly
When I hooked it up on the bench according to the OP's method (after first testing it with the method I have suggested) I saw wisps of smoke within seconds from the surface-mount resistors in series with the "I" terminal. When the reg detects a non-charging condition, it applies ground to this terminal in order to light the indicator. The resistance of the lamp limits the current to as safe level. No lamp=smoke.
You MUST ground the reg case (this should be the first connection made), and you have to add a wire from the A term straight to Batt+ (this wire actually carries the current to the field, not the reference as I stated before. The reference is applied to the S term via the ignition switch.
Go by the labels on the reg, not the order, as Ford used 2 different plugs.
« Last Edit: May 15, 2013, 10:25:16 AM by Pinhead »
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline cben750f0
Re: Replacement Regulator/Rectifier CHEAP
« Reply #1 on: August 09, 2006, 03:36:36 AM »
g'day mate, you wanna do a 'how to' and put it in the FAQ???... i think everyone would like it...peace
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #2 on: August 09, 2006, 03:46:28 AM »
Frank Cooper has done the same in UK:
http://homepage.ntlworld.com/frank.cooper1/frameset.html
He designed and built his own regulator though.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
    • TVAM
« Reply #3 on: August 09, 2006, 03:48:41 AM »
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline dusterdude
« Reply #4 on: August 09, 2006, 06:24:26 AM »
are the recitifiers a radio shack item?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #5 on: August 09, 2006, 09:26:15 AM »
Why is it every time I finish twisting the last bolt on my replacement mousetrap, along comes another one.....
Thanks for the tip, and the savings.
Radio supply houses and electronic parts distributors for tv repair etc should be able to help out. If a zener diode is good enough for a Triumph, why not and RCA!
« Last Edit: August 10, 2006, 10:39:09 AM by GoatBaSS »
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #6 on: August 09, 2006, 07:16:09 PM »
Great information. Thanks, one and all!!
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
fourplay
« Reply #7 on: August 10, 2006, 08:20:24 PM »
Way to go guys. it's stuff like this that keeps these old machines on the road.
I was thinking about some kind of "voltpak" like Harley uses. Rectifier and regulator all in one. I have seen these posted on parts suppliers web sites, but they want $100 or so for them.
I am into amatuer radio as another hobby, but know just enough to be dangerous. Thanks for engineering this stuff.
Vance
Offline Pinhead
  • 1979 CB652-ST
« Reply #8 on: August 10, 2006, 11:24:37 PM »
I don't think you can get them at RatShak, but I haven't really checked. It seems that their electronics selection has gone close to nill.
You can get them here for $2.50 apiece:
http://www.allelectronics.com/cgi-bin/item/FWB-352/110/35_A_200_PIV_BRIDGE_RECTIFIER_.html
Edit: Radio Shack has rectifiers, though they're 50v and 25a. For safety, I'd suggest at least 100v but if you really want to try...
http://www.radioshack.com/product/index.jsp?productId=2062584&cp=&origkw=rectifier&kw=rectifier&parentPage=search
« Last Edit: August 24, 2006, 03:07:38 PM by Pinhead »
Doug
:D
Offline dusterdude
« Reply #9 on: August 11, 2006, 09:09:41 AM »
groovy,thanks pinhead
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Pinhead
  • 1979 CB652-ST
« Reply #10 on: September 01, 2006, 06:23:01 PM »
Has anyone else tried this? If so, what experiences have you had thus far?
Doug
:D
Offline Bodi
« Reply #11 on: September 01, 2006, 09:58:17 PM »
I've used a few of the 3-phase ones on assorted bikes - the second picture in the first post. I use the IR 36MT-20, 35A/200PRV and get them here from Electrosonic, you can get them from Allied Electronics and probably lots of other places in the USA. They were around $10.00 Canadian 2 years ago as I recall. The 35A one is the highest rated "small and cheap" one I could find, and it has proven to be enough on a 750. Higher rated 3-phase bridges are available but get up in the $100.00 range, I couldn't find one between 35 and 160 amps.
You need to bolt it to a heat sink, I used a computer CPU cooler heatsink (probably for a 486 or the first pentium) with the fan removed - from a surplus store - and it is adequate. The heatsink contact on the rectifier is either gounded or isolated - I don't recall - so the heatsink can be screwed to the frame. You could use the fan - it's always a 12V unit - if you want to be extra sexy.
If you can find cheap single phase bridges they're fine too, but you need 2 of them - also attached to a heat sink. Just connect the "+" terminals together and to the battery +, connect the "-" terminals together and to ground, and use any 3 of the four remaining "~" terminals for the yellow wires.
Offline Pinhead
  • 1979 CB652-ST
« Reply #12 on: September 25, 2006, 02:43:03 PM »
This should work on all of Honda's regulated alternators. It wouldn't work on the permanent magnet alternators, but should work on any of Honda's three-phase systems (500, 550, 650, 750, 900 and probably more) that has a center coil, whether it's a coil on the side cover or an electromagnet coil on the crank end. Has anyone else tried using the regulator?
« Last Edit: September 25, 2006, 03:55:36 PM by Pinhead »
Doug
:D
Offline Bodi
« Reply #13 on: September 25, 2006, 03:20:13 PM »
The VoltPak is for permanent magnet alternators.
Offline Pinhead
  • 1979 CB652-ST
« Reply #14 on: January 02, 2007, 01:32:13 PM »
btt
I edited the first post for a mistype in the directions of installation.
Doug
:D
Offline SD750F
    • My Business Site
« Reply #15 on: January 02, 2007, 04:01:48 PM »
Please do not buy anything from Radio Shack... I know they can be a great supply that is local but my experience with them is that the parts they sell as slightly sub par and just barely meet the manufactures specifications...
Here is a link for one of the best Silicon Manufactures that is stocked by Digi-key one of the best internet order electronic distributors around for small high quality parts:
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=308579&Row=143110&Site=US
Scott
Offline Pinhead
  • 1979 CB652-ST
« Reply #16 on: January 21, 2007, 12:11:13 PM »
btt I edited the first post to add my charging diagram.
Doug
:D
Offline Pinhead
  • 1979 CB652-ST
« Reply #17 on: February 16, 2007, 11:43:46 AM »
Bringin it back to the top for whoever hasn't seen it.
Doug
:D
Offline Jim F
  • go baby go
« Reply #18 on: February 17, 2007, 07:56:37 PM »
there is a company  called elctrex that make after market Regulators & Rectifiers
I run one my GS 2 vavle motor and it does away with the old stuff and puts it all in one housing for better charging. If your doing a ground up resto then you dont want this
Have had good luck with this and I sure that they make one for the SOHC hondas too
http://www.electrexworld.co.uk/erol.html
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline Pinhead
  • 1979 CB652-ST
« Reply #19 on: February 18, 2007, 11:46:02 AM »
They do, but they're $100 or more. The home-brew R/R is only around $15...
Doug
:D
spaceboy412
« Reply #20 on: April 01, 2007, 07:15:14 PM »
would the regulator pictured with the link work on a 78 cb550k?
Offline Pinhead
  • 1979 CB652-ST
« Reply #21 on: April 01, 2007, 08:58:53 PM »
The regulator should work with any and all of Honda's charging systems. As long as the field coil's resistance  is similar to that of the CB650 (actually all of Honda's motorcycles to my knowledge). In other words, YES.
Doug
:D
Offline Pinhead
  • 1979 CB652-ST
« Reply #22 on: April 10, 2007, 09:04:33 PM »
BTT for anyone interested.
Doug
:D
Offline jevfro
  • 1975 CB750 K5
« Reply #23 on: April 24, 2007, 03:01:18 PM »
it seams these "cheap" regulators arn't so cheap anymore...
When I put in my zip code it quoted me $47....
Any other cheap sources?
Benjamin
« Reply #24 on: April 24, 2007, 04:33:51 PM »
This guy makes excellent stuff -- reasonable prices and lots of customer service.
www.oregonmotorcycleparts.com
