Author Topic: How do i hook up a dwell meter?  (Read 1880 times)
Offline hevykevy420
« on: August 09, 2006, 02:51:04 PM »
Ok, i broke down and obtained a dwell/tach meter.
How do i hook it up?  does it hook up to the coil and then just a ground? or do you hook up to points somehow?  if to the coil, which wire?  there seems to be a bunch of wires coming out of the coils.
i've down the feeler gauge, but have no idea how to hook up the dwell meter.
1978 CB750K - 836 Wiseco kit, 4-1 Kerker Exhaust, Web cam (63b grind), HD valve springs, polished stuff.  Comfortable.
1975 BMW R90/6 - tight
2002 RC51 - Jardine slip ons.  Uncomfortable.
Austin, TX
Re: How do i hook up a dwell meter?
« Reply #1 on: August 09, 2006, 03:25:56 PM »
Connect the meter's red wire to the points wire, right at the points. The other one goes to the engine case (ground). That's all there is! Be sure to select 4-cylinder mode or double the 8 cylinder reading (not like I didn't in a recent post.   :-[  ).
Offline hevykevy420
« Reply #2 on: August 09, 2006, 03:32:26 PM »
not sure if this is a stupid question - does it matter which end of the points?
Is the connection the same for checking RPMs?
Austin, TX
« Reply #3 on: August 10, 2006, 09:06:47 PM »
Connect to the points where the wires bolt on to them. And, yep, that's the same for checking RPM.
