Author Topic: Running 3 Ph motor on Single Ph  (Read 4019 times)
Offline mick7504
« on: August 02, 2013, 03:32:14 AM »
I've got a 3 Ph Air Compressor that I want to run on Single Ph. 415/240
Does the input need to be a10A or 15A or doesn't that matter?
There appears to be a few different ways of doing this.
The simplest way that I've seen is to change the connection from Star to Delta on the motor and then add in some running capacitors.
I'm no sparkie but have a very basic understanding.
Has anybody done this before or have any other suggestions?
If I was you
I'd be worried about me.
Offline jgmmgood
  • You don't need proof when ya got instinct.
Re: Running 3 Ph motor on Single Ph
« Reply #1 on: August 02, 2013, 06:07:58 AM »
It can be done, and there are multiple ways to accomplish this.  A google search will point you to a few options, but it seems like you will be better off in the long run to just convert the motor to single phase.
Overall, I believe any conversion may be adverse to the 3 phase motor and will burn out the windings in short order.  You will also loose some HP in the orig. motor setup doing this and you may need to have a way to "start" the compressor motor turning on initial start up each time.  I would say if its probably safer and cheaper in the long run to switch the motor out to a single phase.  (this is without knowing if there is an advantage to having 3 phase in your shop for other things as well.....That may change the equation).
Jim
Lookin' is for free, Touchin's gonna cost ya sumthin - Chaz Michael Michaels.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #2 on: August 02, 2013, 07:04:26 AM »
     Whoa! Way beyond Me Brother, but I'd sure like to see what the outcome is. So, I'm tuned in here.  :)
Member # 1969
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #3 on: August 02, 2013, 10:16:08 AM »
Yeah, like jg said either change out the motor or you will need to get a 3 phase converter. Either option is going to cost you a few hundred dollars.
Offline mick7504
« Reply #4 on: August 02, 2013, 11:00:49 AM »
Thanks for your replies and suggestions fellas.
I appreciate it and I'll do some more homework on this and keep you posted on progress.
My garage here at home only has single phase and I need more compressed air to run a bead blaster.
This compressor is in reasonable condition and has been in storage for quite awhile due to the 3 Ph power supply.
Thanks again.
If I was you
« Reply #5 on: August 02, 2013, 11:02:47 AM »
Mick, what is the electrical grid system in Australia?   Any chance of having 3 phases installed?
I quess because you are metric country, I suppose the installation makes more sense than in good ole USA:)
« Last Edit: August 02, 2013, 11:04:24 AM by 70CB750 »
Offline Bailgang
  • Scott
  • Indiana
« Reply #6 on: August 02, 2013, 11:15:00 AM »
A guy I worked with bought an old compressor off our employer that had a 3 phase motor. What he did was talk to the man in our purchasing dept who got him in contact with a supplier that rebuilt electric motors and was able to work out a trade with his 3 phase motor for a comparable single phase motor.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline mick7504
« Reply #7 on: August 02, 2013, 11:28:11 AM »
Mate our single Ph is rated at 240v and 3ph is 415v.
A mate has 3ph at his place and he's got 3 single Ph meter boxes on the power pole at the front of his place.
I don't know how they get 3 x 240v to equal 415v.
I heard that the power mob here in Darwin were putting restrictions on 3 Ph supply for domestic applications.
If I was you
« Reply #8 on: August 02, 2013, 11:35:11 AM »
I see.
The 415 is between phases, 240 is between phase and zero.  In USA, 3 phases are limited to industrial zones, I would love to have 3ph in my shop :(
Over in Czech, houses get 3ph - there is nothing better than 3ph motor.
Anyway, it does not hurt to check on your options, you could pay for 3ph same money as for new 1ph motor.  And 3ph motor is superrior to 1ph, there is no question about it.
« Reply #9 on: August 02, 2013, 12:09:46 PM »
I was going to suggest picking up a used 3ph motor and making a rotary phase converter, but if the 3ph motor is a higher voltage than the single phase power, you would also need a step-up transformer. The 3ph spindle motor on my mill is 240V, and the single phase power is the same. The phase converter runs off the single phase power, and acts as a generator for the 3rd phase. You can sometimes find 3ph motors for cheap; I took a 25 HP to the recyclers last year and got about $45 for it.
If you decide to switch to a single phase motor, you may need to go a bit larger on HP. How big is the compressor?
Offline mick7504
« Reply #10 on: August 02, 2013, 12:37:25 PM »
G'day Scott
I'll dig the compressor out and see what its rated at.
The sun will be up here in a couple of hours and everyone out of bed by then.   ;D
I was using it to supply c/a to a medium size workshop many years ago.
It's a single piston compressor with reasonable size reservoir.
I'll put some pics of it up here as well mate.
If I was you
Offline kghost
« Reply #11 on: August 02, 2013, 02:40:48 PM »
Watching.
Getting a decent air supply on single phase can be challenging.
In Texas on a busy day... I used to run 2 compressors in tandem lol.
Stranger in a strange land
Offline mick7504
« Reply #12 on: August 02, 2013, 03:28:21 PM »
Mornin Tim
This bead blaster I have is a compressed air hog and I think if this motor can keep up to the task and a decent reserve of air it should work out ok.
My curiosity with this 3 to 1 conversion has got my head going.
We can only try mate.
If I was you
« Reply #13 on: August 02, 2013, 07:32:05 PM »
Good evening Mick. Be aware that air compressors have higher starting torque requirements than say a mill, lathe, or drill press. The quick and dirty conversion to single phase most likely won't work.
According to the nameplate stamping, my 2HP 3ph spindle motor can run on either 230 or 460V, depending on the jumper selection; check your motor to see if it has different voltage settings.
Three phase motors are much more efficient than single phase (80+%) and rotary phase convertors are almost 100% efficient.
Offline mick7504
« Reply #14 on: August 02, 2013, 09:51:09 PM »
G'day Scott
Your right about the phase convertors mate.
I think that it's time to get the crocodile out of my pocket and bite the bullet.  ;D
I hooked it into the single phase and the motor spins up but it's nothing to write home to Mum about.
There was an old starting capacitor that I found in the shed but it made absolutely no difference.
It possibly was shot anyway.
Maybe a running capacitor might have been the way to go but I couldn't find one.
Here's a couple of before and after pics and also one of the ID tag on the motor.
It was worth a try I guess.
 3 Ph wired
1 Ph wired
Motor ID Tag
If I was you
« Reply #15 on: August 02, 2013, 10:18:49 PM »
Looks like your motor isn't a good candidate for running off single phase 240V even with a phase convertor... :(
« Reply #16 on: August 03, 2013, 01:25:20 AM »
+1
I think you would burn it soon running it on 1 phase.
Here in USA, due to grid limits is a good supply of strong single phase motors.  When I found out the 1hp motor in my new to me Walker-Turner cabinet saw is not strong enough, I was able to find 6.5HP compressor motor in farmer's store for under $200.
Offline mick7504
« Reply #17 on: August 03, 2013, 01:54:20 AM »
That is the only way to go with a single phase motor now.
When I saw the price on the rotary converters from 6.5 HP onwards, I changed my mind in a hurry.
I'll have a look around and see what's available from the US.
All that will need to be changed is the drive pulley which will be available locally.
The 3 phase motor that's on there at the moment has got about a 28mm shaft with an A section pulley.
Thanks for your help guys.  ;D
If I was you
« Reply #18 on: August 03, 2013, 02:03:35 AM »
Good luck, Mick.
Pulleys can always be made, when hard to find.
Here is a place I used before:
http://www.surpluscenter.com/electric.asp?catname=electric
Offline mick7504
« Reply #19 on: August 03, 2013, 02:31:33 AM »
Thanks for the link mate.
That will be a good start.
If I was you
« Reply #20 on: August 04, 2013, 10:42:04 PM »
G'day Scott
Hey Mick, that must be a very large single lung compressor if it needs a 5 HP motor to spin it? My shop compressor is a two-stage unit, and the primary cylinder has a 4 5/8" bore. With a 3 HP single phase motor, running a compressor RPM of 514, it is rated for 15 CFM@ 125 PSI. With a 5 HP motor, spinning at 826 RPM the pump is rated at 24 CFM at the same PSI.
Offline mick7504
« Reply #21 on: August 05, 2013, 12:23:26 AM »
G'day Scott
G'day Scott
I stuffed up mate and told a fib - It's a twin.
I've no idea what brand the compressor is but there "might" be a book on it somewhere hidden away in the files.
The other thing that I've been thinking about is whether a 5 HP single phase motor will do the job.
Here's a few photos of the single I mean twin.  ;D
If I was you
« Reply #22 on: August 05, 2013, 01:16:03 AM »
Hey Mick, why not bolt a 5 HP Briggs and Stratton engine on that sucker and park it around the back of your shed? Won't be as nice as electric of course, but I doubt you'll get a single phase electric motor big enough to run it, and those phasers cost more than a good compressor!
I've got a 3 phase Brobo Saw that someone gave me a few years ago. I bought a single phase motor for it on eBay and I can machine up an adapter plate on my lathe, but I need to get a rotary speed control switch for it so I can use it for cutting both steel and aluminum. Cheers, Terry. ;D
« Reply #23 on: August 05, 2013, 01:32:53 AM »
I was going to suggest the same thing Terry just said, there should be a number of small petrol or diesel engines that would successfully run that compressor...
Offline trueblue
« Reply #24 on: August 05, 2013, 02:07:28 AM »
I'm pretty sure you can only go up to about 3hp on 240v Mick.  Even then they need to run on a 15 amp power supply ;D
1979 CB650Z
