my #2 cylinder is having moments on/off where it's dying.
i just noticed that i can see spark coming out the SIDE of the plug boot...sparking against the top of the inlet where the boot inserts.
i switched the boot with the #3 cylinder...same boot now on #3 position, i see the same sparking.
i wasn't aware that the boots could go bad...is that what's going on here with the #2 boot?
or is there potentially a bigger problem (e.g., wires and coils)?
was planning to order a set of dyna wires...wondering if i should also spend the extra$ for the coils too.
or is the source of problem elsewhere?
