Author Topic: Ever have one of those days?  (Read 1738 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« on: August 07, 2013, 04:55:21 PM »
(note: it actually kicked over on that one kick :P)
--Evan
1975 CB750K "Rhonda"
Offline fmctm1sw
Re: Ever have one of those days?
« Reply #1 on: August 07, 2013, 04:59:20 PM »
I must say, I've never leaped in the air like that kicking over a bike.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline evanphi
  • Apparently I'm an
« Reply #2 on: August 07, 2013, 05:17:31 PM »
I stand on the kicker then drop all my weight onto it. Helps with cold starts. Warm starts I can do by hand!
--Evan
Offline youn6372
« Reply #3 on: August 07, 2013, 05:20:57 PM »
Yesterday, for the first time in I can't even remember I kick started my bike and it started right up.  I have to admit I had a bit of a smile on after that.
1973 CB750K
1982 CB900F
1983 VFR750
1983 CB1100F
1988 CBR1000F
Offline LesterPiglet
  • 1977 CB550F2
« Reply #4 on: August 07, 2013, 05:23:02 PM »
What's that you're kicking, a 600 single?   :P
Offline phil71
« Reply #5 on: August 07, 2013, 05:23:21 PM »
You should try that little button on the right hand control.
Offline evanphi
  • Apparently I'm an
« Reply #6 on: August 07, 2013, 05:49:31 PM »
If you watch closely you can see my lip bite of determination. I always have a smile on after kicking it over. I kick it all the time. Good start to my ride, and helps me feel more at one with the bike.
--Evan
Offline Powderman
« Reply #7 on: August 07, 2013, 09:21:52 PM »
You've never  owned a Harley then. lol
Offline 750K
« Reply #8 on: August 07, 2013, 09:38:13 PM »
Ahahahaha
77 Cb750, 78 Kz1000
Offline youn6372
« Reply #9 on: August 08, 2013, 04:38:35 AM »
I totally agree.  These something special about kicking starting a machine and having it turn over on the first kick is even nicer.
1973 CB750K
1982 CB900F
1983 VFR750
1983 CB1100F
1988 CBR1000F
Offline Fritz
« Reply #10 on: August 08, 2013, 06:09:02 AM »
+1. I always kick start my bike - to save battery juice and just because makes the bike feel so antique :)
But I don't get this "even nicer, if it starts with the first kick". Isn't it supposed to do that all the time? I've never had problems, even in winter at 30°F, to start the bike with the first kick. Maybe it's a maintenance issue... or the 550 is just more eager to start up :)
1976 CB550F
Offline youn6372
« Reply #11 on: August 08, 2013, 06:21:22 AM »
"Isn't it supposed to do that all the time?"
Now lets try to define it.
I guess when you have owned as many kick start bikes as I you can start to see subtle differences.  My K3 starts up every time on the first kick.  Have you ever tried to kick an old Harley when the weather was 30 degrees out?  Its all about the technique your using for that specific bike and its different from bike to bike.
1973 CB750K
1982 CB900F
1983 VFR750
1983 CB1100F
1988 CBR1000F
« Reply #12 on: August 08, 2013, 06:30:06 AM »
It just have a different roar when you kick it.
Offline 72 yellow
« Reply #13 on: August 08, 2013, 06:32:21 AM »
Or a 64 Sportster with 12-1 compression and a magneto when it's cold out.  That will give you a good cardio workout.
« Reply #14 on: August 08, 2013, 06:38:03 AM »
Have you hand started your bike?   I've always head of guys doing it and I tried it, pretty cool.
Offline evanphi
  • Apparently I'm an
« Reply #15 on: August 08, 2013, 06:39:39 AM »
Yeah I can hand start it when it is warm and not a lot of muscle required. When Cold I don't want to risk pulling the bike over on me! The gif is from a cold start. I put all my weight onto it and it goes first kick.
--Evan
Black 750K8
« Reply #16 on: August 08, 2013, 07:48:19 AM »
+10 My first one had the distributor that you adjusted with the left grip like a throttle  no auto advance set that thing wrong and it would kick you back. Plus I was 17 110 lbs I use to turn that grip while riding and think my carb was screwed up ::) Those were the days
Offline evanphi
  • Apparently I'm an
« Reply #17 on: August 08, 2013, 11:04:33 AM »
Every ride sounds like an adventure in hand-eye-foot coordination.
--Evan
