Author Topic: Rear shock/spring assembly  (Read 997 times)
Offline davidtime
« on: August 09, 2013, 04:11:35 PM »
Anyone have a trick to getting rear springs compressed to put the spring back on the shock without the tool?
Re: Rear shock/spring assembly
« Reply #1 on: August 09, 2013, 04:15:15 PM »
I have seen pictures with the spring hold by many zip ties for the installation.  I believe gnarlycharlie  (member here) have done it that way.
Offline reddyvv
« Reply #2 on: August 09, 2013, 04:15:57 PM »
I found the best way to get a good grip on it is to put the lower mounting point in a vise and get someone strong to pull down on the cover while you insert the stops.
Offline Elan
    • Vital Motor Parts
« Reply #3 on: August 09, 2013, 04:17:39 PM »
yeah I did the "pull down " method. just make sure the tension adjustment is set to the easiest setting
76 750k
Offline davidtime
« Reply #4 on: August 09, 2013, 04:33:47 PM »
I don't have to have the cover on it do I?
I dont even have a vise but I think I can come up with something. Gave me an idea though. Think I will attach it to an old swingarm and do it.
I swear the springs got longer than they were when I took them off.
Offline davesee
« Reply #5 on: August 10, 2013, 05:19:24 AM »
i used compression straps.
1980 honda cb650 with many weekends worth of modifications.
Offline Xnavylfr
« Reply #6 on: August 10, 2013, 06:21:48 AM »
NO, you don't have to put the cover back over the springs. It really helps to have a vise to squeeze the springs down then you can ziptie or safety wire them. If you have a way to lift the back of your bike from above ,this trick helps.. Install the shocks with the springs in place, lift the back of the bike so that the shocks are at full extension then have someone push down on the springs so you can install the half-moon locks.
Xnavylfr(CHUCK)
Offline tomkimberly
« Reply #7 on: August 10, 2013, 12:34:57 PM »
You can make your own spring compressor like this. All it took was a saw, drill, and hammer.
Tom
Offline davidtime
« Reply #8 on: August 10, 2013, 02:52:38 PM »
I didn't think zip ties would hold but all I needed was that and I made the 8" 3-jaw puller I bought and the exhaust hanger (actually I was about to take the puller back) work. Originally I was trying to do it with the spring on the shock but the puller would pop off. So I compressed it off the shock after some trial and error it worked. First one took a few but the 2nd one took seconds.
Thanks for the zip tie suggestions and all of the others. Saved me 32.00 from the local shop.
« Last Edit: August 10, 2013, 02:54:27 PM by davidtime »
« Reply #9 on: August 10, 2013, 03:44:34 PM »
Glad it worked!
Offline davidtime
« Reply #10 on: August 10, 2013, 06:05:12 PM »
Heres a  bad photo
