Author Topic: Not what I wanted to see..  (Read 8074 times)
Black 750K8
Re: Not what I wanted to see..
« Reply #25 on: August 11, 2013, 01:23:14 PM »
You will really feel the difference that old tire is hard as a rock. I just got a BattleAx rear 120/90/17 rear sooo nice. It had a 130 from PO. I never new such a small change would make such a difference. The old tire looks flat in the middle with sharp corners on both sides and when leaning I could feel it drop on and off those edges. I just got use to it and didn't notice how bad it was. No more big tires on little rims for me.
« Reply #26 on: August 11, 2013, 07:59:06 PM »
mmm new tires :)...flat out my favorite thing to get for any bike
Offline toytuff
  • "watching the pinheads"
« Reply #27 on: August 11, 2013, 08:04:27 PM »
 :D
tt
« Reply #28 on: August 11, 2013, 08:11:49 PM »
Flat out?  Pun intended, Sean?!
« Reply #29 on: August 11, 2013, 08:14:13 PM »
sure, why not...I knew there was some reason I used those words ;D
« Reply #30 on: August 12, 2013, 01:24:44 AM »
thanks stevo,we only seem to have four or three if its pre 2000,my new 501 today has 0913 only in that border
Offline toytuff
« Reply #31 on: August 16, 2013, 06:47:45 AM »
Long story short.  ::)
I thought I ordered a 110-90-19 tire but the tube type was in fact a 100-90-19. No worries there but I ordered a 110-90-19 tube. Dang it!
Will the 110 tube still work in a 100 tire? If not I'm buying another tube.  :-[
tt
Offline lucky
« Reply #32 on: August 16, 2013, 10:54:11 AM »
What is those marks on your rotor?
A reflection of the diamond plate the bike is on.
Very good LesterPiglet!!!
I was going to say reflection but you nailed it.
Offline lucky
« Reply #33 on: August 16, 2013, 10:55:18 AM »
Well this is interesting. Tires were replaced by PO. I just noticed on the back is a tubeless tire running a tube.
The only size I can find is a 110-90-19. It has a 110-80-19 on it now. Would the (90) be wider?
tt
That is acceptable . Slightly lowers the rating thats all.
Offline lucky
« Reply #34 on: August 16, 2013, 10:56:25 AM »
How old are the tires ? Wasn't there a recent thread about new Avons cracking also ?
   No. Never heard of that but if you leave your bike out in the 100ยบ sun they will look like that in one year.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #35 on: August 16, 2013, 02:45:33 PM »
Is the tube really that specific? I know bicycle tubes cover a range of sizes. I can't believe that 10mm will make a difference.
Offline toytuff
« Reply #36 on: August 16, 2013, 04:13:29 PM »
Well, I played it safe and returned the tube. Bought the correct size. The right one was $7.00 cheaper than the wrong size so with return shipping label they provide it was hit the "easy" button.
Just have to wait a few more days. It was my mistake. Thanks guys.
tt
Offline toytuff
« Reply #37 on: August 21, 2013, 06:46:01 AM »
Up at 0300 hrs. waiting on the shop to open at 0800. Dang, I need a nap!
So, quickly. Dunlop tire. Yellow dot opposite of valve stem or on the stem.
I thought I read opposite of stem. Heavy side.
tt
Black 750K8
« Reply #38 on: August 21, 2013, 07:08:50 AM »
tt
Don't know about Dunlop but my bridgestones are marked for the light spot yellow spot by the stem.
Offline toytuff
« Reply #39 on: August 21, 2013, 07:10:02 AM »
Yellow dot goes to stem if I read it correctly.
I think I'll have them put the rim only on the balancer and see where the heavy side is located. I'm not a fan of wheel weights unless the spoke type which they never have.
tt
Black 750K8
« Reply #40 on: August 21, 2013, 07:10:33 AM »
We need some Dunlop guys to look. So here is a bump.
Offline toytuff
« Reply #41 on: August 21, 2013, 07:12:32 AM »
I did some searching and found out. Goes to stem hole but that is not always the case.
tt
Black 750K8
« Reply #42 on: August 21, 2013, 07:14:43 AM »
tt
Yes but that is mine I would think they would all be the same maybe someone with Dunlops will see this or you can try Dunlops site to find out. I MIGHT trust the guy at the shop if he is an oldtimer.
Black 750K8
« Reply #43 on: August 21, 2013, 07:16:51 AM »
tt
Yes I can remember when the mark was the heavy spot
Offline toytuff
« Reply #44 on: August 21, 2013, 07:21:35 AM »
tt
"In GOD we trust, everything else we check." I learned that when taking flying lessons. Never forgot.
tt
Black 750K8
« Reply #45 on: August 21, 2013, 07:25:09 AM »
tt
tt
I always check the riggers work before I left the plane ;) Was it not Reagan that said trust but verify.
« Reply #46 on: August 21, 2013, 07:27:07 AM »
Spoke weights only, my guy carries em chrome plated for the "Harley guys" [and me]
Offline toytuff
« Reply #47 on: August 21, 2013, 09:35:54 AM »
Well this went smooth. 25 minutes in and out.  8) The shop also carried both in spoke weights. Took very little weight.
Mounted and ready to go. Now the Dream is next. Pinched the tube. Not attempting, take it in.  ::)
tt
« Reply #48 on: August 21, 2013, 05:32:02 PM »
Wait wait wait, what about that back tire?  What is the date code?
