Really? I had no idea. Why is that?
Anyway, I did go outside and check the plugs after I posted this, and I checked half the plugs (two on each side in the front since they're the easiest to get to). Most of them were on the lean side.
I only thought it was rich because at idle it smells fairly rich, and after bogging the engine at WOT it smells rich in the cabin. But obviously the plugs say otherwise.
I cannot find a jet kit in stores here (checked the big 3 as well as the local speed shop), so I'd have to get it off Amazon or something. The O'Reilly with the speed shop has most of the jets, rods, and springs in stock though. It's roughly $55 for a jet kit and $25 for a set of rods and jets, so I get two tries to get it right by buying individually, so I'm not sure which is worth it. Plus the individuals are on island.
What should I be doing? An automotive carb is foreign to me, but I'm trying to understand it (I have one of those how to modify/rebuild edelbrock/carter carb manuals).
Is there anything I can do with the timing, maybe retard it a few degrees?
