Author Topic: Need help with ID of RC piston application  (Read 9111 times)
Online PeWe
Re: Need help with ID of RC piston application
« Reply #75 on: October 06, 2013, 02:04:05 AM »
Yes, I saw that earlier when looking for new rings for my Action fours 836 pistons that use CB350 twin +1mm rings. Cheap sets of rings that were OK except the oil rings.
RC can use same as AF (I compared the pistons) but difficult to find today. Here sold out. http://bore-tech.com/product/350-piston-ring-set-65-mm
My NOS cast RC pistons have the old 3 piece oil rings from my AF pistons. I thought that old 3 piece will be better than a new 1 piece oil ring. Ring end gaps within the spec. I have to check my old rings I have and save as spares....
-Or what about Wiseco rings?
« Last Edit: October 06, 2013, 02:24:34 AM by PeWe »
Online PeWe
Re: Need help with ID of RC piston application- Update with CB750 porn-
« Reply #76 on: October 09, 2013, 04:05:14 AM »
Finally running engine with RC pistons as this thread started with. Tank is not the final with good paint OEM style. Gas leaks sorted.
The engine is running with 3 NGK Iridium plugs and one NGK D8EA on 4:th cyl. (Bad mistake when tighten 3:rd plug, cracked the isolator, new ordered + 1 extra)
The ignition is not checked with strobe lamp either. Ordered together with carb sync tool
http://www.ebay.co.uk/itm/AccuSpark-H8000-Timing-lamp-Gunson-carb-balancer-/190559985200
Carbs are also running rich on idle. Will set air screws better when ignition is finally verified, now according to PAMCO description, middle position.
Change attached files extension from jpg to mp4 and hear.
Offline Tews19
  • I am no
« Reply #77 on: October 09, 2013, 05:45:09 AM »
Hmm... links not working.
1970 Honda CB750 survivor.
Online PeWe
« Reply #78 on: October 09, 2013, 11:54:56 AM »
yes, they works if you download and then rename the file extension from jpg to mp4. This was plan B when I could not upload my minimized videos.
Offline Tews19
  • I am no
« Reply #79 on: October 09, 2013, 12:02:42 PM »
How do I do that? I saved as is, but no option for file conversion
Online PeWe
« Reply #80 on: October 09, 2013, 01:51:05 PM »
Just rename file in file manager.... :-)
