Author Topic: Need replacement front carb boots for 1978 CB750F will these work?  (Read 1262 times)
Offline nzdreamer55
Hello everyone,
I need to replace with either NOS or aftermarket boots for my 1978 CB750F.  The parts for it are listed as
16211-410-000    INSULATOR 1, CARBURETOR Not Available
16212-410-000    INSULATOR 2, CARBURETOR   $18.67
16213-410-000    INSULATOR 3, CARBURETOR Not Available
16214-410-000    INSULATOR 4, CARBURETOR Not Available
http://www.buymotorcycleparts.com/honda_parts.htm#/Honda/CB750F_A_(78)_MOTORCYCLE%2c_JPN%2c_VIN%23_CB750F-2200001/CYLINDER_HEAD/CB750F-78-JPN-A/2Y134102E13410202A
I can find these from parts n more but the numbers are slightly different (they look identical)
Intake Carb Holder Set
#48-0756    | Honda CB750F (1979-1982)
Intake Carb Holder Set OEM Ref#16214-425-00 1 Pc, 16213-425-00 1 Pc, 16212-425-00 1 Pc, 16211-425-00 1 Pc
http://www.partsnmore.com/parts/honda/cb750f/?filters[category]=carb&filters[fitting]=custom
But they are listed for the 1979-1982.
Any idea if these will work?
Thanks
-S
Offline Xnavylfr
Re: Need replacement front carb boots for 1978 CB750F will these work?
« Reply #1 on: August 18, 2013, 06:28:09 PM »
First!  MOST all aftermarket sellers will only take a picture of one set of boots and list them differently by part number according to year/model.
The ones listed for 79-82 CB WON'T work. The DOHC CBs had larger and different carbs.
Xnavylfr(CHUCK)
Black 750K8
« Reply #2 on: August 18, 2013, 06:51:49 PM »
No they will not you are sol. The best thing you can do is  the old double up trick that does work fairly well but not perfect. Honda still sells 1 &3 and you will need two of each. There is a post with a guy making new ones I don't know if he has started yet. Look in parts for sale. I think that is where I saw it. He is trying to get enough people to sign up for a first run.
http://forums.sohc4.net/index.php?topic=120377.0
