Author Topic: frame, Matt or Gloss  (Read 8350 times)
Offline billy192
« on: August 19, 2013, 07:15:02 AM »
Hi,
CB750 K6 (in the UK)
just about to get my frame powder coated question is Matt Black or Gloss?
thanks
Billy
Offline WrenchMonkey
Re: frame, Matt or Gloss
« Reply #1 on: August 19, 2013, 07:29:30 AM »
I believe that the stock color was semi-gloss black, if that's what you're going for.  Really a matter of personal opinion though.  Are you going for a resto, or a custom?   What do you think will look better for your particular application?  In my opinion, for what it's worth, I like the look matte finished frames.  However, glossy frames are easier to clean.
John
Jack of all trades, master of none.
'71 CB750 K1
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: August 19, 2013, 09:18:32 AM »
Neither, semi-gloss. See the pics about half way down the page: http://forums.sohc4.net/index.php?topic=117164.25
« Last Edit: August 19, 2013, 10:44:08 AM by Bankerdanny »
Offline billy192
« Reply #3 on: August 19, 2013, 10:05:21 AM »
 :-\so that's  semi gloss or is it satin?
« Reply #4 on: August 19, 2013, 10:27:14 AM »
Have them semi-gloss clear over the black for extra protection and appearance.
Offline Dream750
« Reply #5 on: August 19, 2013, 10:42:50 AM »
Your 750 K6 originally used Honda black paint code: NH1 on the frame, swingarm, chain guard, oil tank, kickstand, center stand and lower triple tree which has a gloss factor. This NH1 gloss factor tends to fade out over time when exposed to light and then becomes subjective. I would suggest using the front of the oil tank as the original factory paint has been protected/preserved by the side cover. This is usually the best sample to match up when going for originality.
Offline camelman
  • Man... Myth... Legend
« Reply #6 on: August 19, 2013, 10:54:18 AM »
Matte always looks dirty to my eyes.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline billy192
« Reply #7 on: August 19, 2013, 01:24:24 PM »
thanks dream750
then lets go for gloss then
Billy
Offline KennyRedman
  • 1976 CB550F, Indiana
« Reply #8 on: August 19, 2013, 02:00:26 PM »
I got mine powder coated in satin:
As for gloss, check out SohRon's opinion on his gloss black powder coat in his thread
then powder coated gloss black, and I'm not sure I'd do the high gloss again; at least not in a dark color. The black powder coat is so glossy and fragile that it required a special clear overcoat (at extra cost) to protect the finish. The problem is that the overcoat is kind of fragile itself, and shows every fingerprint and micro scratch. There are areas in the finish that are a Little cloudy now from attempts to clean off fingerprints. Even Microfiber cloths can scratch the finish. I'm thinking that eventually I'll have the frame redone, but have it coated with the semigloss finish which is still pretty shiny, but a little more forgiving. Still, it does look nice
YMMV
Offline billy192
« Reply #9 on: August 19, 2013, 02:10:35 PM »
Ok Satin looks the best all round finish.
thanks for the pics KennyRedman
Billy
Offline sethdhawkins
« Reply #10 on: August 20, 2013, 05:10:28 AM »
I have mine in satin and wish I'd gone with gloss. It does always look dirty.
All a man needs in this world is someone to love, if you can't give him that, give him hope, if you can't give him hope...just give him something to do!
1972-ish CB750K
1974 CB450
1974 CB360
1976 136' Ocean Going Tug
Offline lucky
« Reply #11 on: August 20, 2013, 07:38:21 AM »
It is a trick question and it is all in how the powder coaters present you your choices.
If you say "gloss" they might charge you more because they have to put clear over it.
If you say I would like it shiny but not "high gloss" Then it will be glossy but not high gloss. They just will not spray it with clear.
You save money because they only spray it once and bake it once.
They sell spray cans now with a product to make you powder coat shine.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #12 on: August 20, 2013, 08:15:39 AM »
Smoother the better. Makes it easier to clean grease and oil off of it.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #13 on: August 20, 2013, 10:55:21 AM »
My CB750 frame is recently painted in black 2k. Not gloss and not matte. Gloss grade 50 if I remember correct.
The painter recommended this and it looks good. Easier to repair if scratched.
Offline Vin750
« Reply #14 on: September 14, 2017, 07:02:31 AM »
Hi Dream750,
I am restoring a F2 and I am struggling to identify the type of black that went on the engine.
Would you have any info on that?
Thanks
Offline Wbflyer
« Reply #15 on: September 14, 2017, 10:44:20 AM »
I just started painting my frame and went with satin.  will cover with clear satin or semi-gloss.
« Reply #16 on: September 14, 2017, 10:50:35 AM »
750f2 and f3 frames were gloss finish from factory, (says my three examples).
Offline bleach8484
« Reply #17 on: September 15, 2017, 09:54:10 PM »
Ill be going with a satin aluminum/silver here in a few weeks.
1974 CB550 Resto mod in progress - May be finished before 2018
2013 Triumph Thruxton Mildly modded
Offline Vin750
« Reply #18 on: September 15, 2017, 09:57:24 PM »
What about the engine?
« Reply #19 on: September 15, 2017, 10:12:22 PM »
I only have an F2 and an F3 engine.  Neither are as glossy as the frames, which polish up quite shinny.  Pretty sure it's different paint than what is on the frames.  Much thinner application, too, which you'd expect from a heat radiating surface.  Don't want a barrier for heat transfer between engine to air.
From the pics I've seen of the bike in their heyday, the engines were as shinny as the K model aluminum paints on that engine.  Black just isn't as reflective without some glare to set it off.
Offline Vin750
« Reply #20 on: September 15, 2017, 10:34:06 PM »
Thanks, matching that black paint on the engine has been hard so far. I will do some more research.
Offline beemerbum
« Reply #21 on: September 16, 2017, 08:45:23 AM »
If you are going to use paint (cheaper and easier to touch up), somewhere in this forum I read about Rustoleum appliance epoxy paint for the frame, black of course. I have used it on two frames thus far, I get compliments on how close to original they look.
Offline Vin750
« Reply #22 on: October 05, 2017, 11:43:38 AM »
Thanks I will do some research.
