Author Topic: Has anyone used KBS RustBlast?  (Read 463 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: August 19, 2013, 01:37:56 PM »
http://www.kbs-coatings.com/rustblast.html
I'd like to not have to use a tank sealer (Caswell, POR15 etc) if it all possible, but am always on the lookout for better rust removal solutions. Supposedly it:
"effectively dissolves rust, corrosion, metal oxides, and tarnishing from most metal surfaces, while providing extended protection against flash-rusting thanks to KBS' unique Oxygen-Block technology."
Sounds like if you clean it out with this stuff, as long as you immediately dry it out & fill it with gas you should be okay. Anyone have any experience with it?
