Author Topic: F3 triple on K3 frame  (Read 1004 times)
« on: August 22, 2013, 05:15:40 AM »
I am planning on using this combo, since I have forks and wheels too, but now I am thinking steering geometry and not so sure anymore.
What do you think?
Offline jaguar
Re: F3 triple on K3 frame
« Reply #1 on: August 22, 2013, 05:28:06 AM »
Tony Foale wrote a great book on the subject.
Worth a read if you want to set up a bike properly.
Plenty of people swap all manor of inverted forks onto sohc bikes.
I personally have not seen anyone do the math for spring rates and such.
Don't know how much they ride either.
« Reply #2 on: August 22, 2013, 05:34:20 AM »
Thank you.  I will get the book and educate myself a bit.
I figured I could always swap the triple if she behaves badly.
Offline andrewk
  • doin' it.
« Reply #3 on: August 22, 2013, 06:04:22 AM »
What do you think the problem will be with the geometry?  Most publications say the the rake is slightly different f to k, but it's all in the triple tree offset- at least that's my understanding.
« Reply #4 on: August 22, 2013, 06:07:33 AM »
The trail will be shorter than K3 had.  I also have to use F swingarm to get in the wheel, we shall see  :)
« Reply #5 on: August 22, 2013, 03:02:50 PM »
Gday Prokop, its exactly the opposite mate, smaller offset of the F3 clamps {50mm compared to 60mm for the K}  will slightly add more trail, seeings though there is only 10mm difference in the offset the change will be minimal.
« Reply #6 on: August 22, 2013, 04:22:28 PM »
You are right of course, thank you!
« Reply #7 on: August 22, 2013, 04:28:33 PM »
Too easy.... ;D
Offline jaguar
« Reply #8 on: August 22, 2013, 05:27:11 PM »
Also I had assumed he was talking about a cbr F3 swap for some reason.
Offline Roach Carver
« Reply #9 on: August 22, 2013, 07:18:02 PM »
you are talking 77/78 f right? If so I have that exact setup in a 71 cb750. no problems at all.
« Reply #10 on: August 22, 2013, 07:35:52 PM »
RR, what do you mean they don't. I put them on mine. I have it in the garage right now? I rode it... lots. I agree they are different offset in the trees. the swingarm is also an inch longer on the F.
the largest modification was removal of the passenger peg mounts. You need the aluminum ones on the 77/78 f bike. Other than that there was no real issues.
Sorry Roach, I miss read your post, I just deleted my response... 8)  I thought you meant they were the same.... ;)
« Reply #11 on: August 22, 2013, 07:40:22 PM »
No worries Mick.
« Reply #12 on: August 23, 2013, 03:32:42 AM »
Yes, 78F.
Offline jaguar
« Reply #13 on: August 23, 2013, 01:19:24 PM »
What are you going to do about the mismatched wheels?
« Reply #14 on: August 23, 2013, 02:15:54 PM »
Only the frame is K3, swingarm, wheels and fork and engine are F. It fits together, i had it mocked up, but it is waiting on a full head job.
« Reply #15 on: August 23, 2013, 02:49:16 PM »
The easiest way to do the back end is to get the 77/78f peg brackets. The right side has the pedal and master. You will have to cut  the passenger peg brackets off the frame but the new brackets will have the passenger brackets. The swingarm bolt is also longer.
