Author Topic: Installing throttle cables and choke cable? *FIXED RUNNING VID  (Read 10993 times)
Offline Moffman
  • 1979 Honda CB650
Putting the carbs back on and I already have them installed with the boots and airbox. Now all I have left is the cables and the fuel tank and it's ready to go. However the cables are proving to be a lot more of a pain then I thought. I definitely should have installed them before installing the carbs all the way.
Any tips or suggestions? It's pretty hard to even get two fingers down there let alone the pull cable.
« Last Edit: August 23, 2013, 04:40:37 PM by Moffman »
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
Re: Installing throttle cables and choke cable?
« Reply #1 on: August 23, 2013, 01:40:51 AM »
Assuming everything is connected at the twistgrip, slacken off all the adjustment in the cables first.
Locate the cable ends in their respective places at the carbs, and ensure the inners sit where they should be. You'r kind of working backwards if you see what I mean.
If you then keep the cable taught by pulling back on the outer, you should then be able to slot the adjusters into the brackets and adjust.
It can be a bit fiddly, but unless you've got hands like the Incredible Hulk you should be ok.
Hope this helps.
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline Magilla
  • My bike: 1976 CB750F
« Reply #2 on: August 23, 2013, 05:29:55 AM »
A small pair of needle nose pliers with a 60 degree bend made this job super easy for me this year.  The pliers were under $5 at Harbor Freight.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #3 on: August 23, 2013, 06:02:22 AM »
You DO have the Gas tank off right?  ???
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline wowbagger
  • Not much of an
« Reply #4 on: August 23, 2013, 06:22:44 AM »
+1 on the pliers. It's also far easier to take the threaded cable adjuster out of it's bracket and seat the end of the cable first.
Offline Moffman
  • 1979 Honda CB650
« Reply #5 on: August 23, 2013, 04:40:01 PM »
Thanks for the tips, I headed over to HF to pick up the pliers and just my luck they were having a parking lot sale. Picked up a thermometer gun for only 25 bucks.
Anyway the long pliers turned out to be usual as they were to thick to open once I got near the cable. But just in case anyone is in a similar situation the easiest way was the push cable first pretty self explanatory, don't install them yet in the bracket either like my first picture. I just did that to make sure I had the routing right. The pull cable is pretty much impossible if you don't give it slack from the grips.  Once you have loosened the adjuster, guide the ball end of the adjuster under the throttle bracket and with a very thin pair of needle nose pliers grab the ball and pull up and over until the ball is seated (it helps to guide the back of the cable as well doing this). And choke was easy just guide it down, unscrew the hold down bracket for the cable and remove it, with the bracket out of the way you can use some decent pliers and guide the cable down while simultaneously using two fingers under the carbs by the bowl and seating the ball.
Here it is running.
https://www.youtube.com/watch?v=s820a19Iel0
https://www.youtube.com/watch?v=Qacq5Ci2BLo
Offline Magilla
Re: Installing throttle cables and choke cable? *FIXED RUNNING VID
« Reply #6 on: August 24, 2013, 07:30:32 AM »
Looks nice and clean.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline jean jacket patrick
  • Mr. Jean Jacket Patrick
  • JJP JJP JJP
« Reply #7 on: February 27, 2017, 09:41:33 AM »
Hey Man,
I have the same Carbs and I was wondering if you could post a picture of how you have these setup, specifically the  inlet side for air flow and choke. I bought a 77 CB750 a while back and have been restoring it. I'm pretty close to having it running but I can't figure out how that choke/backside of the carbs is supposed to be setup. I think I'm missing some parts or something.
Thanks I'd really appreciate the help.
-JJP
Mistakes We're Made
