Author Topic: Once again, need help. Gas tank venting Question  (Read 545 times)
Offline RainsongCB750F
« on: August 23, 2013, 04:04:29 PM »
Okay, 78 cb750F. Runs very nicely. Idles smooth, good amount of power. etc. BUT, after a few mins of riding, usually 10 or 20 mins, it starts to bog down and then cut out. So i pull over when this happens, open the gas tank cap, and it fires up. And there is almost always a suction and breath from the tank when i unscrew the cap. SO there is obviously a venting problem going on.
Little background
Stock air box
stock pipe
clean idle jets and all
accel pump works
How can i make my tank vent properly?? Where is the venting port? help
1978 CB750F
When Jesus comes back he will ride an SOHC4.
Re: Once again, need help. Gas tank venting Question
« Reply #1 on: August 23, 2013, 06:11:45 PM »
The vent is in the gas cap itself.  On the bottom you should see a small notch or slit the must be open.  Inside the cap there is a hat to keep the splashing contained.  Somewhere on the top of the cap is a hole.  Air must pass between the hole on top and the slit/notch on the bottom.
  Look closely at the cap and you should figure it out.
Black 750K8
« Reply #2 on: August 23, 2013, 08:19:43 PM »
Just pop out the inside of the cap then you can clean in there. The inside is held in by four prongs. While off you can replace the rubber gasket. scroll down for pics.
http://forums.sohc4.net/index.php?topic=35056.0
« Last Edit: August 23, 2013, 08:22:25 PM by Black 750K8 »
