Author Topic: CB450 Swingarm Rebuild  (Read 7047 times)
fendersrule
Re: CB450 Swingarm Rebuild
« Reply #25 on: September 12, 2013, 06:48:15 PM »
After the dust caps arrived, I installed them (and the missing washer).
With the dust caps, I had absolutely NO struggle seating the swing arm. It was a perfect fit...slid right in.
Torqued to 75-foot lbs.
The swing arm has NO lateral movement. I can lift it to any with minimal force, and it stays. I think I read that this means a job well done.
« Last Edit: September 12, 2013, 06:50:01 PM by fendersrule »
« Reply #26 on: September 12, 2013, 06:51:42 PM »
Is it me or is the swing arm upside down?
fendersrule
« Reply #27 on: September 12, 2013, 07:56:15 PM »
You are right. The shock bushings should face up.
Good call on this. I would have obviously found this when installing my new Hagon shocks which are on the way.  :o
Swapped it around, and torqued it a little more this time to 80 ft-lbs.
Glad this was over. If I had a hydraulic press to remove the stock bushings, I would be more than willing to do this for members here. Because I don't, it's too much manual ass-kicking labor. :(
« Last Edit: September 12, 2013, 08:13:56 PM by fendersrule »
« Reply #28 on: September 12, 2013, 08:27:10 PM »
It aint you.....HA! Good one......
« Reply #29 on: September 12, 2013, 09:36:43 PM »
Impressive... ;D   "obviously" you should have known this first.... ::)
Priceless... ;D ;D
« Reply #30 on: September 13, 2013, 01:50:44 AM »
Everybody has senior moments :)
Good job on the swingarm, fendersrule!
Senior Moments by Golf Brooks - Call 352-391-0626 For Bookings & CD Sales!
fendersrule
« Reply #31 on: September 13, 2013, 08:30:11 AM »
Took a whole 1.5 minutes to reverse.
At least I have confirmed that you can install a swing upside down just fine. :)
« Reply #32 on: September 13, 2013, 08:56:08 AM »
I thoughtthat was the OZ instalation..
>>>>>>>>>>>>>>>>>running away>>>>>>>>>>>>>>>
« Reply #33 on: September 13, 2013, 09:38:33 AM »
Just a test if we pay attention. :)
This smart a$$ mechanic in the army was sure that I am a total idiot, so he greased caterpillar wheel bearings on T-54 with strawberry jam.  LOL, it looked almost like the military grease we used,  but I caught it.
He spent the whole weekend cleaning it up and doing it again.  I may be an idiot, but I have my bright moments  ;D
« Reply #34 on: September 13, 2013, 01:47:11 PM »
No second prizes Frank, and you know what thought done.... :o
